Old 06-25-2010, 02:42 PM
Marsdy Marsdy is offline
Default Re: "Some regions had invalid bounds and were adjusted or deleted"
DTS
Not in the studio again until Monday but I can say that it seems a cosmetic problem. I've not lost anything. Not tested this scientifically but it looked like the greyed out files appeared in the region list when I was undoing and deleting record passes. Was trying to hit a deadline so I didn't have time to really look into it.
I've never changed the record path from the default or moved/copied files or folders in the finder.
It's happening in sessions created in 8.0.4 but based on a template created in earlier versions.
Dave Marsden
UK
Old 06-25-2010, 02:55 PM
T-Low T-Low is offline
" Has anyone actually seen a file go missing, or does the message seem to be a red herring and nothing is actually going wrong? "
Cant detect any losses so far, but the pop-up is ....
I "think" it is related to new ( 8.x ) sessions
Old 06-25-2010, 04:33 PM
WernerF WernerF is offline
I've been getting it on sessions that were created on 8.0.4. Nothing appears to actually be missing. Crossing my fingers though as the sessions that it has been cropping up on have only one or two audio files at this begining stage of the project that it is happening on.
Old 06-25-2010, 06:02 PM
WildHoney WildHoney is offline
Originally Posted by DigiTechSupt View Post
If you look at the full path name - are the audio files in the location where Pro Tools is expecting to see them?
Can anyone provide any more details that may help us narrow down the cause? Were these sessions created in a previous version? Can you reproduce this in a new session? Has anyone actually seen a file go missing, or does the message seem to be a red herring and nothing is actually going wrong?
Any detail you can provide would help us immensely in tracking down the problem.
OK. Just opened a file started on 8.0.3. Got the error message upon opening. No files missing. No grayed out regions in region list. File is playing fine.
Old 06-25-2010, 06:23 PM
GlennR01 GlennR01 is offline
I've had the same alert window, but I have noticed a difference in files. After comping vocals and fine tuning breaths (yes, fun), non-crossfaded regions moved from their original in and out points. In other words, if I did not place a cross fade between two differing regions, the boundaries of those regions had slightly moved.
This is NOT a good thing. Only since 8.0.4, doesn't discriminate regarding original file creation OS or PT version.
Mac Pro 2013 2.7GHz 12 Core 128GB • Mac OS 10.5.5 • PT Ultimate 2020.5.0 • PT HDX3 • 192 IO x 8 • D-Control 32 Fader • UAD2 Octo Ultimate
  #16
Old 06-25-2010, 07:06 PM
ZEUSS ZEUSS is offline
I am getting this almost every time I open a session since upgrading to 8.04. All new sessions created on 8.04. Even on a template with one file in it.
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
  #17
Old 06-26-2010, 01:08 AM
innesireinar innesireinar is offline
Same here. And when I undo a record pass regions (in italic, like those with missing audio files) remain in the region list.
Avid HDX - Avid HD I/O 16x16 Analog - Pro Tools Ultimate 2023.6 - Nuendo 11
Mac Pro 5.1 2 esacore 2.66 64GB Ram - Mac OS 11.7.7
  #18
Old 06-26-2010, 10:18 AM
lownotesinc lownotesinc is offline
+1
My session was created on 8.03.
  #19
Old 06-26-2010, 03:46 PM
BigEvil BigEvil is offline
I've been having this issue for a while now with no apparent solution. Spent some time on the phone with Tech Support and wasn't able to solve the problem. http://duc.digidesign.com/showthread.php?t=268769
Seems like "An Access Violation Occurred" has a cousin whose come to visit us in 8.0.4
  #20
Old 06-27-2010, 12:05 PM
blackbirdstudio blackbirdstudio is offline
Even though this error message appears randomly, it doesnt seem to affect anything in the session here...
Dave
2.66 Ghz Quad-Core Intel Xeon, OS 10.6.3
HD3 Accel, Control 24, PT 8.1 cs1
Has "Some regions had invalid bounds and were adjusted or deleted" been fixed? meech Pro Tools TDM Systems (Mac) 22 06-21-2014 12:47 AM
"Out of Bounds" / "Invalid bounds" bug still exists! 12StringJ Pro Tools 10 1 07-21-2013 12:34 PM
Some Clips Had Invalid Bounds and Were Adjusted or Deleted Bug! Siegfried Meier macOS 2 01-28-2013 07:32 AM
pt8 won't open session (some regions had invalid bounds and were adjusted or deleted) terryrocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 10-26-2011 11:02 AM
"Some regions invalid bounds and were adjusted or deleted" A duplicate Audio Folder ! acmost Pro Tools 9 0 11-13-2010 05:40 AM
