Re: Is this typical performance?
Something's definitely going on there, because the system usage shouldn't be near 62% with that few tracks. Running that on my 2007 Imac doesn't come anywhere near that.
Again, thanks for your replies chaps.
The computer came installed with 3GB in 6x 512k cards. I then augmented them with a pair of 2GB cards from Crucial. The 2GB cards occupy slots 1&2 on the first riser. The internal drive is a nice idea, but like I say, on my old G5 I can stream sessions of 80+ tracks without a problem with hard drive speed so I'm hesitant to say that it might be part of the issue. My playback dialogue settings are: H/W Buffer Size: 1024 samples Host Processors: 4 Processors (maximum) CPU Usage limit: 95% Delay Compensation: Long DAE Buffer Size: Level 2 Cache Size: Normal Plug-in Streaming: Optimized for streaming content from audio drives As I say, the computer itself is rather sluggish for what should be a fairly well-specced machine. It is not the newest, but the G5 boots up more quickly and takes less time to launch programs. There are also occasional graphics glitches. The graphics card has been upgraded by the previous owner. Any chance that it might be hogging CPU and causing the problems? |
Carl
PT 2021.10 HDX 16x24 -Mac Pro 12 Cores 48 GB RAM OS 10.13.6 - API 16 channel - AMS Neve 16 channel, AMS-Neve-SSL -Pres/Processing, Bock Audio, BLUE Bottle, Neumann, Josephson -Mics, Bogner, Kemper- Guitar, Chandler Zener-Curve Bender Outboard/Master. UAudio, Waves, Plugin Alliance etc. |
Using a larger Plug-In Streaming Buffer Size leaves less system memory for other tasks. The default setting of 250 ms (Level 2) is recommended unless you are experiencing problems with the reliability of streaming playback from disk. Unless you're using Structure, make is as low as you can.
“What fresh hell is this?” - Dorothy S. Parker |
Again : 10.6.7 is NOT qualified by Avid. Bring it back to 10.6.6
System Details: Macbook Pro 17" OS 10.7.5 PT 10.0 8 gig ram FW Drives (Multiple) eSATA Drives (Multiple) [email protected] |
OK, thanks for all your ideas, much appreciated!
Any thoughts on why the computer itself might be slow outside of Pro Tools? Like I say, the boot-up on it is arduously slow, slower than my G5 and nowhere near the same as the Mac Pros at the studio. |
I would first change the video card, especially if it's glitching like you mentioned. Then only use matching ram, then reinstall.
MAC PRO 2010 5,1 3.46hex 128ram - MONTEREY 12.7.4- PT 2024.3 / 003 RACK SIGNATURE MOD / DIGIMAX FS / PCM90 2CHANNEL SPDIF
I'd check to see what apps are installed/running at startup. Have you checked Activity Monitor?
Activity Monitor is showing nothing running other than the tiniest of scripts. 0.8% of CPU in action when nothing is running.
I have taken out all of the 512mb sticks of RAM and PT is now a lot happier! Many thanks to those who suggested it. Looks like I'll be getting rid of these! |
How can the computer boot up be real slow? Funny that is ... definitely something to do with RAM there ....
Also ... all my machines work fine with 10.6.7 ... |
Typical Car EQ Settings? | timmy4402 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 06-21-2007 09:48 AM |
Typical Car Stereo EQ? | timmy4402 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-20-2007 10:50 AM |
wat r typical eg settings for?? | Jesus H. | Tips & Tricks | 5 | 01-17-2005 01:24 PM |
System Performance - Is this typical? | Mightypudge | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-28-2002 09:33 AM |
let me know if this sounds typical or what... | moe green | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 13 | 03-27-2001 05:47 PM |
