Old 09-30-2003, 07:27 AM
Tim R. Tim R. is offline
Default Reason/Rewire/Pt\'s tempo stuck @ 120??
Whenever I have a session with Reason Rewired into no matter what I set the tempo at, when I save/close/reopen the session the tempo has reset to 120bpm. Sessions without Reason don't have this problem.
PT's 6.1 Mix/24
OS 10.2.6
G4 Dual 533
Reason 2.5
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
Old 09-30-2003, 07:43 AM
MAXIMUSIC MAXIMUSIC is offline
Default Re: Reason/Rewire/Pt\'s tempo stuck @ 120??
You have to make sure that you set the tempo in Protools with the conductor track "tempo map", this way you lock the tempo in Protools and any rewire application will then follow it.
Life is good !!
Marcello Azevedo
Old 09-30-2003, 08:41 AM
So using a rewire app requires the conductor track to be on? While the session is running Reason follows any tempo changes I make in the transport window (without the conductor "on") but won't stick?
Tim
Tim Reisig
Old 09-30-2003, 09:02 PM
Let me try to explain my own research on that matter...
I found out (the hard way) that any Rewire Master Application will follow the last changed Rewire slave, that means if you have Protools (master) running at 90bpm and you make any changes on a slave app. (like loading a Rex file into Reason's Rex player) the PT bpm will follow the Rex file original bpm. That is why I suggested you to lock the bpm on Protools by enabling the conductor track.
I'm not sure if that is the way it should be, but..........
It worked for me !!!
Hope this helps
Life is good !!
Marcello Azevedo
Reason Rewire MIDI volume fader stuck grateful 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-25-2011 12:58 PM
strange Reason/Pro Tools rewire tempo issue scullionj 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-26-2010 05:53 AM
ReWire Reason 4 & ProTools LE 8 Tempo Not Right musiclovin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 02-08-2009 12:25 PM
Protools tempo stuck at 120 bpm?! MaxEssE 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-29-2004 11:44 AM
Help with Reason into PT's steals 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-28-2002 12:47 AM
