Old 06-11-2020, 08:42 PM
EddieJones's Avatar
EddieJones EddieJones is online now
Default EUCON 20.6.1 Now available
Avid is pleased to announce the release of EUCON 20.6.0 with bug fixes and performance enhancements for S1, Control App and other EUCON surfaces. Download it from your Avid Account or the Avid Download Center. Note: The old MyArtist site is no longer updated, find instruction on it for getting access to the Download Center.
Release Notes
EDIT: Updated to 20.6.1 to fix Incorrect tracks in Layouts and Layouts not appearing in the Control App after switching DAW focus. The current 20.6.0 Control App is what is supported with this release.
Old 09-03-2020, 09:28 AM
Lcepeda Lcepeda is offline
Default Re: EUCON 20.6.1 Now available
I'm still encountering the same issue even after updating to Eucon to 20.6.1. i have deleted the software and installed it several times. does anyone have this same issue.
Old 09-03-2020, 10:17 AM
EddieJones's Avatar
Same issue?
Old 09-18-2020, 08:34 AM
Tonemeistr Tonemeistr is offline
Hello,
I was using Eucontrol two weeks ago and everything was working fine. Last weekend I tried to use it and nothing. My iPad would show up in the devices window but it would not connect. I checked the version on the computer and it is 20.6.1. My iPad is 20.6.0. So I thought there was a miss match with firmware so I tried to go back a version and it downloaded and installed and then vanished. I tried to download 20.6.1 and same thing; downloaded, installed and vanished. Now I have no Eucontrol at all. I bought an ASC code from Avid for $40 and never got a code. I got a receipt and Avid has my money but I'm dead in the water. I hope someone here can help.
Thanks,
Mike
Old 09-18-2020, 09:33 AM
EddieJones's Avatar
Originally Posted by Tonemeistr View Post
Hello,
Hi Mike, sorry for your issues. Correct versions are 20.6.0 on the iPad and 20.6.1 EuControl.
Are you Mac or Windows? Either way run the 20.6.1 Installer select Remove all Apps and remover all prefs, after reboot then run the installer again
Old 09-18-2020, 12:00 PM
Eddie,
Thanks for getting back to me. I will try that. I am using an iMac. Where will I see "Remove all Apps and remover all prefs" after rebooting? Because after rebooting previously nothing appeared as an option.
Thanks,
PS - What do I do about getting my $40 back?
Mike
Old 09-18-2020, 12:44 PM
EddieJones's Avatar
Eddie,
Thanks,
Mike
Run the EUCON Workstation installer and you will see the checkboxes. Out of interest...what did you install...should have been the very top checkbox only.
PM me with any details of the case/$40 etc you have
Old 09-18-2020, 01:06 PM
So I did what you suggested and still no Eucontrol. I don't know where it goes but it disappears. I have been checking the Eucontrol Workstation Checkbox. It is not the top checkbox however.
Mike
Old 09-18-2020, 01:17 PM
Hallelujah!! I picked the top box and it worked. Thanks for the help.
Mike
Old 09-18-2020, 04:34 PM
EddieJones's Avatar
We have renamed the EuControl Workstation line to make it more clear in the next release. It's meant for adding a 2nd WS to the system. So don't feel bad as it was confusing others.
Eucon 3.2.2 installer error + firmware downwards compatible with eucon 3.1 deauditievedienst Artist Series 2 07-14-2021 09:33 AM
Eucon 3.6.1 - eMix 6.1.0 - No Eucon channel meters Rpro System 5 14 08-04-2017 11:20 AM
Updated to Eucon 3.6 and lost all my custom Eucon commands bassmagnetic Avid S1, S3, Dock and Control App 0 04-18-2017 10:09 AM
EuCon suddenly broken - Eucon client can not access the bonjour service noiseboyuk Artist Series 0 04-12-2016 12:34 PM
