Old 04-27-2012, 09:38 PM
anth anth is offline
Default next step after warp markers
I have a track in elastic audio mode and have used several warp markers on a group (of drum tracks) to fix some timing issues. Now, if I go back to audio waveform mode, will the markers still be active or should I render a new file using the adjusted track... if so, how is this done? There are 8 drum tracks that have been edited together as a group... do I have to render each seperately?
Old 04-27-2012, 10:10 PM
PD-John PD-John is offline
Default Re: next step after warp markers
If you mean just changing the track views from "warp" back to "waveform", all your elastic audio changes will still be there. However if you want to render the tracks once you're happy with the edits (perhaps to save on processing power), first make a duplicate of the edited playlists so you can still change things if you have to, then select all the drum regions and press Shift + Option + 3 to consolidate them all. Then you can disable elastic audio on these tracks.
Hope this helps.
Cut at warp markers, is this possible chaeffersa Tips & Tricks 3 12-20-2013 07:00 AM
How to turn all Event Markers into Warp Markers ??? fman Pro Tools TDM Systems (Mac) 15 04-29-2011 01:46 PM
All Event markers to warp markers? audioluche Pro Tools TDM Systems (Mac) 9 01-11-2010 06:02 AM
PT8 Warp markers converted 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 03-07-2009 03:40 AM
Warp Markers Inconsistent Mount Royal Pro Tools TDM Systems (Mac) 0 04-17-2008 08:09 PM
