Old 09-13-2018, 07:56 AM
Mattian Mattian is offline
Default Avid says we have to use Ethernet, so it means using iPad's battery?
Well, it's all pretty much in the title... Avid says to use Ethernet instead WiFi, right?
So, to connect the iPad with ethernet I need a lightening adapter, so I won't be able to connect the iPad to power
Am I right?
Do you run it on battery?
It seems so inconvenient to me... and also battery won't last like 8 hours or more
what do you do to solve this problem?
Thanks
Old 09-13-2018, 08:59 AM
BScout BScout is offline
Default Re: Avid says we have to use Ethernet, so it means using iPad's battery?
Nope.
To run it on ethernet you need the Apple Camera Connection kit and the Apple 100Mbit Ethernet adapter. The Camera Connection Kit allows you to power the iPad and Ethernet adapter at the same time. (and it is required to have the iPad on plugged-in power or the Ethernet adapter won't work)
Can't use the 1GB ethernet adapter with iPads
Old 09-13-2018, 03:40 PM
but I don't get how it can power the iPad... I searched camera connection kit and it is a lightening to usb adapter... so if I plug the ethernet adapter to this what will I use to power the iPad?
Old 09-13-2018, 08:36 PM
The camera connection kit has both a usb port (where you plug the ethernet dongle) and a lighting port on one side. The other side is the lighting cable to be plugged into the iPad. So you plug the camera connection kit into the iPad and then on the other side you plug the lighting power supply into one side of the Camera Connection kit and the Ethernet dongle into the usb port. The power supply then powers the ethernet dongle and the iPad at the same time.
This is the one you want:
https://www.amazon.com/Apple-MK0W2AM...connection+kit
And the ethernet dongle:
https://www.amazon.com/Apple-USB-Eth...to+usb+adapter
Old 09-14-2018, 09:17 AM
EddieJones's Avatar
Its not a requirement either...its just a more reliable performance. (I don't use or need one on my system BTW)
Old 09-14-2018, 08:21 PM
mattrixx mattrixx is offline
I also just use the wifi connection. Hasn't caused me any issues thus far.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
MacStudio Ultra / LogicProX / IzotopeRX10+ / SourceConnect / MelodyneStudio5 / WAVES Mercury / NI KompleteUltimate / ProToolsUltimate / RME UFX, UFXII, Babyface / AVID S3 + DOCK / Barefoot MM27 gen2 / Barefoot FP01
Old 09-18-2018, 11:42 AM
Anthony_Anz Anthony_Anz is offline
I use mine WiFi and don't have any issues.. my router is in the same room as my iPad/Dock though. If you're going across a studio or in a different room than your router, I can see how you might need to add an Access Point, or a range extender.
Old 09-20-2018, 02:19 PM
Ok, I hope so... i’m Kind of tired of latencies and stuff... most controllers stop later than the point where you felt it was right... and I hate that thing... so I thought it was imperative to use ethernet... will see if I get it if i’ll be more sensitive than you or if wi fi will be enough
Thanks
Ipad with ethernet! New solution with the new apple USB3 camera adapter Ale Post - Surround - Video 8 05-26-2016 07:06 AM
Ipad PTcontrol with ethernet connection Ale Avid S1, S3, Dock and Control App 1 02-16-2016 09:08 AM
Control App drains battery on iPad mini made Avid S1, S3, Dock and Control App 0 08-20-2015 01:53 AM
Avid releases Avid Studio for iPad nst7 Post - Surround - Video 4 02-05-2012 07:26 PM
Avid iPad Apps Electrox General Discussion 2 03-25-2011 04:12 PM
