Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 11-08-2009, 07:44 AM
zoff zoff is offline
Default Command-space bar not working
I've been using command-spacebar to start recording for may years, but it no longer works on my system. Anyone else having this problem.
macOS Sonoma 14.2 Intel Core i9 MacBook Pro(16,1) 2019, 32 GB RAM Pro Tools Studio 2023.12, RME Babyface Pro
Old 11-09-2009, 07:47 AM
matchoo0 matchoo0 is offline
Default Re: Command-space bar not working
Is the spotlight menu keyboard shortcut using command spacebar? You can change this in the spotlight prefs.
Old 11-09-2009, 04:21 PM
Not it's not. I tried temporarily enabling it for Spotlight to test the short cut and it works in Spotlight, but not Pro Tools.
Old 12-18-2009, 02:20 AM
AdHawk AdHawk is offline
I´m having this problem too. Kinda frustrating after so many years and even worse on the laptop
Old 01-11-2010, 06:20 AM
PKP PKP is offline
Originally Posted by bry View Post
Found the problem. It was a preference plist, completely not related to Pro Tools. The file is located user\Library\Preferences\com.apple.symbolichotkeys .plist I'm assuming this is related to the Keyboard menu located in System Preferences.
Anyways, figure I'd post this incase someone else has the same problem. Running Pro Tools 8.0cs3 with no problems now.
Thanks for the help all.
Mac Pro 2.66GHz 8GB 10.6.2 PTLE 8.0.3
Old 01-11-2010, 07:01 AM
Thank you! Thank you! Thank you!!!
Old 01-18-2010, 02:03 AM
bobywane bobywane is offline
What do you do with the "com.apple.symbolichotkeys .plist" file ?
I found it but I don't know what to do with it to recover the command-space recording...
Thank you
Fab
Old 01-18-2010, 07:05 AM
Thank you
Fab
Move the plist file to the desktop, the system will then create a new one and you will loose your custom keyboard shortcuts. If all goes well you can trash the plist file that you moved to desktop.
Old 01-18-2010, 09:28 AM
OK thank you, I'll try this and tell you if it works on my macbook.
Old 01-21-2010, 04:03 AM
It works !!! But After deleting the plist file the spotlight shortcut preference was reactivated. I desactivated it and now it's working as usual :)
THANK YOU !!!
f12 words, but command space doesn't? hornedrum macOS 7 01-11-2015 09:28 PM
where is the command+space gone ? groovebrother Pro Tools TDM Systems (Mac) 14 11-27-2012 02:16 PM
Option Command Space Bar (Not Recording in sync) adamjay Post - Surround - Video 1 08-17-2010 03:43 PM
TL Space TDM Plugin causes Command 8 to lose communication jacobfarron ProControl, Control|24, Command|8 3 06-20-2008 09:54 AM
can't record with command-space cebolao Pro Tools TDM Systems (Mac) 4 11-14-2001 01:23 AM
