  #41
Old 06-25-2014, 09:19 AM
dalonso66's Avatar
dalonso66 dalonso66 is offline
Default Re: Undipped music stem
Originally Posted by MIKEROPHONICS View Post
How odd of them. It makes no sense as the stems won't add up to the M&E - but hey.
Give them what they want. You can either do it the way you suggested, or have an aux that does the music/FX dip under the sync, which has a pre fade o/p for the stem record. Make sure you only dip the M&E mix under the VO (Narr), otherwise you will be delivering a dipped M&E.
You will have to be careful to dip the right thing at the right time.
Yeah, something tells me the music and effects stems as undipped are not supposed to retain relationship to each other or the full mix balance...
  #42
Old 06-26-2014, 12:12 PM
dalonso66's Avatar
Even doing it that way still requires some careful reworking or counter-dipping of the DME dipper, but yes, I get it.
  #43
Old 07-11-2014, 03:52 AM
wheresmyfroggy wheresmyfroggy is offline
Originally Posted by dalonso66 View Post
I'm trying to figure out a way to accommodate Discovery's Undipped Stems. I usually have an aux set up as a DME dipper to dip under narration. Discovery wants undipped music and undipped fx as if dialog or narration weren't present. Do you guys do all of your dipping of music and effects exclusively on Aux Tracks then take a pre fader send to an undipped bus? Of course if these 2 stems don't need to retain a relative balance to the full mix (i.e flattened for promo purposes) then it won't be hard. I'm currently awaiting some clarification from Discovery.
We are currently having this discussion at work, with regard to the extra time required to mix a flat music/fx then dip that under dial, then make sure that the integrity of that mix is kept when making changes and tweaks further down the line (or if the mix is under time constraints, mix as normal and run through and 'undip' after final client review). I know it depends a lot on the individual project, but has there been any thought to how much extra work this is and whether it is justifiable to make the client aware and pass on the cost?
The way I see it, to be of any use to facilities that inherit these stems for reversioning, the stems have to be 'mixed' and not just flat prefader level, otherwise fx/atmos etc won't be at appropriate relative levels and music crossovers wont work. So it can't be just an automatic process, there has to be thought and attention paid to it.
  #44
Old 07-15-2014, 08:48 AM
dalonso66's Avatar
Yes, The M&E mix retains it's relative balance. I spoke to a former mixer at Discovery and this was his reply:
"The way we set this up internally at Discovery, and how they continue to do it is like this:
Music is leveled on the music tracks (-24ish), but not mixed on the music tracks. All music mixing is on the music & dip busses.
Narration Bus feeds Full Mix
Dialog Bus feeds Dip Bus
FX Bus feeds Dip Bus
Music Bus feeds Dip Bus
Dip Bus feeds Full Mix
So, anytime you're mixing against dialog only, you'll be mixing your FX & Music on the FX & Music bus. When VO comes in, the FX and Music busses go to unity and then you pull the Dip bus down under VO. They send a pre-fader from the Dip bus to create the MDE. This allows for everything to happen in a single pass."
  #45
Old 10-06-2015, 11:11 PM
fork-media fork-media is offline
really struggling on the rationale in this one! its the first time in 20 years I ever been asked to mix sync sound and VO together in mono - and they dot want seperate either?!!
this is a history channel spec sheet I just got given...
Channel 1 Full Mix; Stereo Left
Channel 2 Full Mix; Stereo Right
Channel 3 M&E; Stereo Left (no dialogue, no VO/narration)
Channel 4 M&E; Stereo Right (no dialogue, no VO/narration)
channel 5 VO/Narration and interview/location dialogues;
channel 6 Mono Effects and Ambience/B-roll Audio; Mono
channel 7 Stereo Music & Effects & Dialogue Left (no VO/narration)
Channel 8 Stereo Music & Effects & Dialogue Right (no VO/narration)
channel 9 Stereo Music Left (undipped with clean fades)
channel 10 Stereo Music Right (undipped with clean fades)
if I got sent this to reversion - I think I would be upset! The M+E is basically useless? not an effect driven show,, and they want nat sound mixed with the VO?
I guess ch 7/8 is that one ?
actually the few SFX that are in - are stereo..
way prefer have 3 seperate D M E to do a reversion..
of course the spec sheet didnt appear til after I had basically mixed the show..
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive
Focusrite Saffire PRO 40
Ultimate 2022 10 / HD Avid MC Mix / MC Control
  #46
Old 10-10-2015, 10:14 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Try making an undipped, when your music comes from the offline video editor with cut clip/crossfade at cut/clip gain down under dialogue.
Its a Media Composer way of dipping music.
I actually use that as a starting reference, as the EP has approved the rough music level.
So my dips are minimal, and mostly board fades between music cuts.
IMDB
  #47
Old 10-11-2015, 12:34 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
But you are still providing a dipped music stem if you do that. Having said that, I think this undipped music stem is sheer nonsense and comes from a complete lack of understanding of how people reversion.
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
  #48
Old 10-11-2015, 09:29 AM
No Im not!!
I do know about reversioning.
When I used a board, it was easy!!
I now mix with an AAF that starts this way.
I was saying "try making one from that"
I have to manually go in and restore all the clip gain drops to the nominal levels then remove automation added to that area.
For a reality show that will NEVER go international.
OFF TOPIC:
On top of mixing -24 +- 1, with a short term loudness of +-4
With a peak of -10.
IMDB
  #49
Old 04-16-2018, 07:20 AM
its2loud its2loud is offline
This thread has been dead for a while but I’m about to bring it back to life with THE dumbest delivery requirement to date. Delivering a 22 minute show that contains an on camera host with on camera dialog. The other parts of the show are animated with character dialog as well as host VO over some dialog.
The network specifically requested we treat the on camera host dialog as VO and thus deliver an undipped mix minus VO and an undipped music stem and fx stem. They don’t require an M&E.
Here’s the problem I have with all of this.
1. The relationship of dialog to music and FX changes drastically when the VO is talking over dialog but the MX and FX has to stay a bit louder to help sell the animation jokes. Therefore, mixing with a DME fader does not help.
2. Treating the on camera Host as VO completely eliminates the rule of keeping music and FX dipped under sync dialog since this “VO” is sync dialog!
I get there isn’t always one way to skin a cat but seriously these networks need to conform to ONE way that will work for every territory in the world.
9 out of 10 shows I mix don’t even know what a fully filled M&E is.
HTML code is On
Undipped Mix Minus mrjk79 Post - Surround - Video 2 03-17-2009 02:39 AM
M&E's dipped or undipped? c-post Post - Surround - Video 3 12-23-2006 12:08 PM
Creating different mixes-dipped, undipped, etc. evann Post - Surround - Video 1 07-30-2005 07:34 PM
undipped meaning poldo Post - Surround - Video 4 06-14-2005 01:41 AM
