  #21
Old 04-04-2016, 09:39 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Default Re: PT 12.5 Video Engine
Have you tried that video (or a portion of it) on another rig?
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
  #22
Old 04-04-2016, 10:15 AM
VRS VRS is offline
I have tried 3 different videos from different clients with different CODECs. All the same result. I just made a new user (so no prefs whatsoever) and same result.
Gotta get to work. Going back to 12.4. This is ridiculous.
  #23
Old 04-04-2016, 02:37 PM
friendlybunny friendlybunny is offline
Don't know if you are using Blackmagic Intensity Pro... but the best driver I have used with it is 10.1.4
The newest driver gives me all sorts of errors and problems.
  #24
Old 04-04-2016, 11:03 PM
P_J P_J is offline
Avid video engine was unable to stop.
Still getting this sometimes with 12.5.
  #25
Old 04-05-2016, 03:59 AM
Is it when loop playback is active?
cheers
BAFTA member
IPS member
  #26
Old 04-05-2016, 04:10 AM
P_J P_J is offline
It happens when I hit play after pause. But this has happened only couple of times with a big session. Aja t-tap/AJA 12.2.2 drivers. OS 10.10.5. I have video in separate drive. Long gop video file so that could be the reason.
  #27
Old 04-05-2016, 06:25 AM
Norad155 Norad155 is offline
Video Engine is straight garbage software.
I have used:
All flavors of ProRes, and DNX
On AJA hardware, and BM hardware, as well as floating a QT on 15 different systems on every version of PT12 on all versions of OSX and they all suck... some less than others... but for the $600x15/Year I'm paying for "support" it should work. Every. Time.
It's not cute anymore.
::rant over::
IMDB
  #28
Old 04-05-2016, 08:04 AM
yop22 yop22 is offline
In 12.5 I get the QT floating window disappearing randomly or staying on top of other programs (RX or Basehead for example). It's really amazing that Avid hasn't been able to release a fully working video engine since version 11. It seems the only choices we have are "working badly" or "not working at all".
I think the fact that there is a 50minutes webinar to explain how to troubleshoot the video engine means that there is definitely something wrong with it...
Please Avid, reassign some money from marketing to development...
Win 10 pro, Asus Rog Maximus, i9 [email protected], 64GB
PTHD native, 2x96IO, SSL Delta Link, S3
  #29
Old 04-05-2016, 11:20 AM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
+1.
I said enough is enough and refused paying a fine for HD upgrade to 12, without Avid actually fixing the AVE.
I stay on HD 11.3.2 until it there will be a clear report that the AVE is fixed. Period.
For me the AVE is still in its beta testing. Its not bad but its far from being perfect.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
  #30
Old 04-05-2016, 06:33 PM
garnoil garnoil is offline
Originally Posted by mgoorevich View Post
+1.
I also refuse to pay the upgrade fine to PT12.5 especially because my AVE 'works' in my PT 11.3.2 When I say it 'works', I mean, it is not ideal but..it usable and I have learned to work with it. I am not going to upgrade and take a huge risk to have the AVE of PT 12 not work. My system is on 16 hours a day 7 days week, and I can not afford downtime or an AVE that does not perform as I need. By the way, I am working with 4 other studios and NONE of then are upgrading to PT12
HTML code is On
'The Video Engine reported and error' message when trying to play any video zerothrills Pro Tools 12 10 02-28-2022 04:04 AM
video engine loftus Pro Tools 11 1 08-19-2015 02:15 PM
Video Engine not working.. crashing when i load in a video to PT11 sarahsherlock Pro Tools 11 5 08-16-2014 12:35 AM
PT 10HD with MXF Video wants Video Engine? rantanplan Pro Tools 10 2 06-05-2014 09:50 AM
Boot Screen "Not Recognized Video Hardware Connected", "video engine failed to init bcrichguitar macOS 3 04-01-2012 09:10 AM
