Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 09-11-2020, 02:07 PM
MrKnewitAll MrKnewitAll is offline
Default Customizing Transport Keys
The Avid S6 Guide says:
Drag and Drop Transport Switches
The Automation Module Transport Soft Keys can be rearranged via drag-drop. Drag a key onto another Transport switch and the
two will swap locations.
That's all it says. Can anyone give a brief explanation of how to actually get to this drag-drop area of the Soft Key editor?
I don't have easy access to an S6 surface, but trying to write up a few instructions on more obscure functions.
Anyone who isn't confused, really doesn't understand the situation.
Old 09-11-2020, 02:17 PM
creativecontrol's Avatar
Default Re: Customizing Transport Keys
It is possible to open up an Automation Module and move the switch caps around to match the transport functions that you tweak from the Settings > Soft Keys page on S6. Essentially, if you want to change the arrangement of how the transport switches are organized you can access this page (which shows a visual representation of the switches) and touch and hold to move a switch which ripples / swaps with the switch you hover over.
Jeff
Jeff Komar
Old 09-15-2020, 11:31 AM
Thanks, Jeff. Just what I needed to know.
To move switch caps, does the Automation Module itself have to be opened, or can this be done from the top?
Old 09-15-2020, 11:54 AM
No you can not rearrange the caps from the top of the unit.
Jeff
Jeff Komar
MC Transport displays sample values when Soft Keys pressed-? 01digitalaudio Artist Series 1 07-12-2019 09:13 PM
Bug in Artist Transport - saving soft keys lucienpalmer Artist Series 2 09-15-2014 06:42 PM
pop noise on transport keys STUDIO A 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 11-29-2004 03:40 PM
Customizing PT LE Display FullFreq 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-22-2004 02:30 PM
What the hell did I press? Transport keys deactivated? Burton 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 09-14-2001 02:10 PM
