Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 08-31-2020, 11:28 AM
Redbeard Redbeard is offline
Default Any way to prevent Avid HD I/O default to 192kHz
I've got the HD I/O, loop sync master, feeding a Focusrite 16Line and a Focusrite HD32R.
When protools is quit, the HD I/O defaults to 192kHz, which throws the Focusrite HD32R into 'expansion' mode, so when I restart ProTools, it sees a different number of audio interfaces and makes me quit and restart until I can get it started in 48kHz.
Any way to prevent?
Old 08-31-2020, 01:33 PM
Top Jimmy's Avatar
Default Re: Any way to prevent Avid HD I/O default to 192kHz
Are you on Mac or Windows? If Mac, can you change the sample rate in audio midi setup? If Windows, can you change the sample rate in the Windows audio device settings or via the ASIO driver in a third party audio app?
James Cadwallader
Old 09-02-2020, 12:56 PM
On a Mac. Audio Midi setup doesn't seem to have any settings that would relate.
Old 09-12-2020, 04:33 PM
Top Jimmy's Avatar
Can you access the hardware settings via another audio app using coreaudio?
James Cadwallader
Old 09-13-2020, 11:44 AM
BScout BScout is offline
It is AudioMidi Setup that needs to be changed.
Close Pro Tools
Open AudioMIDI Setup
Go to the "Avid HDX" audio device
At the top in the right column, set your clock source (if using an external word clock otherwise internal). And then in Format, set it to what you want it to default to. (I set mine to 48k)
Old 09-21-2020, 09:33 AM
ZEUSS ZEUSS is offline
Close Pro Tools
So I realized I am using the native thunderbolt and not HDX after I read this again. I change the default sample rate and interface but as soon as the interfaces are turned off and I come back to it, It still defaults to 192. My main issue is I have an apogee DA16X as my second interface after my Red Line 16 and thats what seems to get more confused and "Stuck" especially after changing sample rates... I guess its just something the core audio won't remember in the setup?
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 11-15-2022, 01:57 AM
martthie_08 martthie_08 is offline
every couple weeks I have the "stuck at 192" issue with one of my HD I/O interfaces freaking out, all metering led's fully lit.. it is a major pain and involves multiple reboots / turning interfaces on and off until everything is smooth again.
It would be super helpful to create a startup script for MacOS to change Audio Midi Setup defaults to 44.1 or 48 KHz to prevent the interfaces going to 192 KHz in the first place.
I never go above 96 KHz, which is also a limitation of the 100ft DigiLink cables in the studio.
Old 09-20-2020, 07:09 PM
Awesome! Great info! Been dealing with this issue myself. It always defaults to 192.
Old 09-21-2020, 06:10 AM
uptheoctave uptheoctave is offline
Same thing happens with the MTRX- it is Avid's Core Audio HDX driver, which I am not a fan of anyway.
James Richmond
https://www.jamesrichmond.com
2019 Mac Pro, 2022 Mac Studio Ultra
Avid S6, HDX2, MTRX II, MTRX, DAD AX64, AX32, Focusrite Rednet PCIER, Trinnov MC8 Pro.
Studio: https://www.voltperoctave.com | Music: https://www.euclideancircuits.com
Latest Article: Auto-Bounce for Logic Pro
Affiliate Links:
Auto-Bounce by Tom Salta
Dreamhost Web Hosting
Default download folder in Avid Link? babaorum Pro Tools 2018 0 12-28-2018 02:20 AM
192khz recording capt kirk Pro Tools 9 1 02-12-2012 09:16 AM
Avid Drivers Prevent Sleep - Why? GordonFreeman macOS 63 05-04-2011 07:53 PM
I cant go to 192KHZ KINGDRAGON Tips & Tricks 2 01-29-2010 11:57 PM
How many of you record on 192kHz? mantaray Pro Tools TDM Systems (Mac) 3 07-02-2005 09:18 AM
