Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
  #51
Old 12-17-2014, 09:57 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: SSL waves native
Originally Posted by simon.a.billington View Post
but it's exactly the same pregain on every instance which would lead to harmonic build up in exactly the same space, and that leads to muddy mixes.
Which is why I favoured the approach or the NLS because there are 32 channels of subtle variations there with their own harmonic characteristic, so they are less likely to build up. But as you would anticipate, if I'm using the NLS pregain it becomes a less favourable idea to use them in conjunction with other pregains.
Interesting POV
Daniel
  #52
Old 12-17-2014, 10:35 PM
WernerF WernerF is offline
The only thing that the Analog Button does on the Waves SSL plugin is add a 60 cycle hum. This info is straight from a Waves tech support guys mouth. It's interesting to note how some hear more distortion as a result of engaging it. Once again, no offense intended, the power of expectation bias is quite profound. I would demo each one of these plugins first and then take other user's personal opinion's as extra info into account.
  #53
Old 12-17-2014, 11:11 PM
YYR123's Avatar
He wasn't talking bout the analog button, but yeah I think most people know that the analog button just introduces 50/60 cycle hum
Daniel
  #54
Old 12-18-2014, 02:06 AM
simon.a.billington simon.a.billington is offline
That's right I was talking about the NLS, and in particular I would recommend using it conjunction with the SSL EQ. Pity the NLS a doesn't have an API flavour.
Yeah interesting about that distortion note, could it perhaps be caused by the 60Hz tone causing harmonic modulation with the other frequencies??
  #55
Old 12-18-2014, 07:22 AM
I was referring to references to the Analog button introducing distortion that were sated earlier in this thread.
As for the interaction I suppose that anything is possible but the 60 cycle hum is pretty far down in the noise floor compared to whatever source is being EQ'd, hence the EQ frequencies are going to be way up there in comparison as well.
  #56
Old 12-22-2014, 12:00 AM
Is the Hum pre or post eq??
The reason why I ask is if its post, much of it would be lost when a HPF filter is applied
  #57
Old 12-23-2014, 04:53 AM
Andy Gone's Avatar
Andy Gone Andy Gone is offline
Actually hum will be lost if hum is pre EQ (or EQ is post hum) Gonna try to tweak EQ and see if the hum changes :)
  #58
Old 12-23-2014, 05:18 PM
Yep, that's what I'm saying. Let us know the verdict
WTB : Waves V7 Native maniman Buy & Sell 2 11-16-2015 01:11 PM
FS: Waves NLS Native RaySoul Buy & Sell 5 07-02-2014 03:58 PM
Waves SSL Native Bundle (Inc AAX Native) The Dougfather Buy & Sell 0 11-05-2013 03:58 AM
Waves AAX native JFreak AAX Plug-ins 31 05-13-2013 04:23 AM
Never mind Waves AAX DSP, where is Waves AAX Native? rockridge98 AAX Plug-ins 27 10-24-2012 11:21 PM
