Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 06-21-2017, 02:38 AM
TrentWilliams TrentWilliams is offline
Default Focusrite Clarett 8PreX Pad
Hey everyone,
I just bought a Focusrite Clarett 8PreX, which so far has been great. I upgraded from a 003 Rack which has serves me well.
Was wondering if anyone might be able to help me with some questions about it.
1 - Is there anyway to pad or trim inputs so I can use a preamp with it?
2 - I've been testing it out with a U87, but it's almost as like the phantom power isn't powering the mic enough to drive it. I have to crank the gain to the very top in order to get anything out of the U87, even then it's not great. I heard these pre's were amazing. But so far i've felt quite luke warm about them.
I'm still getting used to Focusrite Control, so excuse me if i'm overlooking something.
Thanks
Pro Tools 2024.3.0|Perpetual • MTRX Studio • HDX1 • Sync-X • S3 • Dock • Mac Mini 2018 - 3.2GHz i7 6-core macOS 13.6 • RAM 64GB DDR4 GPU AMD 6900XT 16GB • Monitor LG 32UL950-W
Old 06-21-2017, 09:32 AM
junkgear's Avatar
junkgear junkgear is offline
Default Re: Focusrite Clarett 8PreX Pad
What troubleshooting have you done?
Assuming everything is connected properly and phantom power engaged, do you get decent input level readings on the input meters?
Have you tried the mic in other inputs to make sure one of your preamps isn't bad?
Does the mic work with other preamps, like your 003?
Have you tried other input sources and do they have sufficient level?
Can you play audio through the unit and is the output level normal?
Will
System Details
Old 06-21-2017, 01:23 PM
Hey thanks for your reply
Yip, connected and phantom engaged.
I'm getting around -24db with gain set to around 5:00.
I've tried the mic on channels 1 thru 8, all the same.
The U87 works fine when I plug it into my SQN4s Series IV field mixer.
I've also tried it with an MKH816T, which I am getting more level out of, but still not what I would call great.
I can play audio out of the 8PreX no problem, it's calibration is out by around 0.1db between Pro Tools metering and Focusrite metering.
When I play audio from iTunes through the 8PreX (iTunes cranked up to full, which should be 0db), all of the clip light indicators turn red on the 8PreX and Focusrite Control.
Old 06-22-2017, 05:25 AM
junkgear's Avatar
How old is your U87? Some of the older models had different output impedance, some had an additional pad and had less sensitivity. I don't remember the details of it, but if you search on the Neumann forms, you will find info on it.
As for using a separate preamp with this mic, you definitely could. Just look for a preamp that offers a line out, which you could run into the line in of the Focusrite. The only problem is that if your U87 is the odd man out, then you will have to try different preamps until you find one that works well with this mic.
Will
System Details
Old 07-15-2017, 02:40 PM
Cutlerbri Cutlerbri is offline
I have had the same issue with my Focusrite Clarret 2Pre and a Neumann TLM102. I have to turn the input gain WAY up to create a level.
And I am equally confused about what Mix Control is supposed to do.
Brian
See profile page for system details
Old 07-16-2017, 10:22 AM
panamajack's Avatar
panamajack panamajack is offline
1 - Is there any way to pad or trim inputs so I can use a preamp with it?
2 - I have to crank the gain to the very top in order to get anything out of the U87. . .
. . . I'm still getting used to Focusrite Control, so excuse me if i'm overlooking something. . .
. . . I'm getting around -24db with gain set to around 5:00. . .
Originally Posted by Cutlerbri View Post
. . . I have to turn the input gain WAY up to create a level. . .
The Focusrite Control windows are where you set the input levels. Channels 1 and 2 can be selected to instrument, line or microphone level. Channels 3 through 8 can only be line or microphone level.
If you want to pad the input, set it to line level. If you are using a mic, but have it set to line level, you will not get the correct level.
The mic preamps have 57 dB of gain, which should be enough for condenser or dynamic mics, but maybe not ribbon mics. I have an Apogee Element which has mic gain of 75 dB. The Apogee also has mic, instrument, and two selections for line level -- either -10 or +4 -- on all the inputs. It also has a "soft limit" feature which rolls off the upper 4dB to prevent clipping.
Attached are photos of the Focusrite Control and Apogee Element setup pages. Either interface has software mixers than permit direct monitoring and individualized headphone monitoring mixes for near zero latency recording.
The output settings are also configured in the Focusrite Control window. The selections made should echo in the Pro Tools I/O setup page.
PT10.3.10HD(Tyan s2932 [8core Shanghai 2.7GHZ] 32GB,Win7 SP1); PT10HD(Tyan s2892 w/10GB, Win7 SP1);PT8HD(Dell 690 quad Xeon 3.0, 8GB, Win7,192 I/O, 96 I/O);MacBook Pro: 11R, Apogee Element 46, Focusrite 8PreX PT HD 11.3.2; Mac Pro 3.47 Hex 32GB, OSX 10.12.6/L10.4.2;L9.1.8, 2.64TB; G5 D2.3 4GB, 10.4.11/L8; 12c MP 2.66/32GB PT12.4; Structure, GigaGS3, Kontakt 5, Garratin, Sibelius 8.7+, Finale26,EMU,Vegas Pro 16-10/; RME HDSP9652,MOTU 2408 MKIII/1224/308, FX,Kurz,L5s,Strat,ASAT,JB,Zon
Focusrite Clarett 2Pre/Clarett Octopre w/PT11 shultzee13 Pro Tools 11 0 03-24-2017 08:08 PM
advice on Focusrite Clarett series lampmusic macOS 3 03-04-2017 06:38 PM
Focusrite Clarett 4Pre and PT11 TheEdster75 Pro Tools 11 6 01-10-2017 07:31 AM
Focusrite Clarett 8 Pre X Cowboy Bob Third Party Interfaces 31 03-12-2016 04:41 PM
New Focusrite Clarett Thunderbolt interfaces nst7 Pro Tools 11 3 01-23-2015 04:32 AM
