random, sporadic "pops"
I record bass using a SansAmp Bass Driver DI.
From that I route an XLR direct (untreated) into one channel of my PreSonus BlueTubev2 preamp (which routes through my MBox3) and a 1/4" jack (treated w/ my BassDriver settings) into a another channel on the PreSonus. Each get their own track in Pro Tools and I route those to a bass bus aux input. 99% of the time I love this setup and find that with a combination of the two tracks I can get exactly what I need in terms of tone (I'm a bass player and a stickler with this.) But what occasionally happens is that I will get a single, very slight pop somewhere in either one or both of these tracks (if it's on both tracks it's in exactly the same spot). It doesn't happen all the time and it always seems to happen only once. It's barely noticeable, but when it happens, for me at least, it sometimes ruins an otherwise good take. Any ideas as to what could cause this? For the record, I don't run any plugins on these tracks when I'm recording. Also for the record, I always make sure that my system isn't running other programs, browser windows, etc. When I'm recording that's all that is active or running. Running PT 11.3, Win 7 Pro 64X; Intel Core i7 960 @ 3.20GHz, 24.0GB Triple-Channel DDR3. Pro Tools project files on a dedicated internal HDD. PT running off a Samsung 840 Pro SSD. Last edited by dg27; 06-11-2017 at 07:56 PM. Reason: typo |
Re: random, sporadic "pops"
If you can lose the Presonus between your bass and audio interface. If you don't get the pop then it's in the Blue Tube. If that's the case you might have the 12AX7 in the BT going bad. Another possibility is, and this depends on how Presonus designed it, but the BT might be running what's called a starved-plate design where the tube doesn't get the full voltage on the plates to properly run the tube. That will compromise the sound and could give out what you're hearing.
Thanks, Jack. I will check these issues out. Hopefully it's the tube; the PS is only 6 months old, but I do use it every day. There is also an option on the PreSonus (a saturation knob) that, when defeated, bypasses the tube entirely. I've always left a nominal amount of saturation; I'll try it without and see what happens.
It doesn't happen often often for it to be a major concern and like I said, the pop (it's always only one) is really very, very faint. I doubt others other than engineers would even notice it. What's annoying is that when it does happen, it's always on a take I really like . dg |
Another possibility: if your playing gets vigorous enough, could it be a string hitting a pickup? Or the pick(if you play with a pick)? I get loud ticks on acoustic guitar(depending on the player) and its almost always the pick hitting the body
Another thought which goes along with hard playing - strings slipping in the bridge or nut when doing bends.
Thanks, Jack and Dave.
I don't think it's a mechanical noise, mostly because, for one, it definitely does not correspond to any "hits" (I play with a heavy pick). And if it did I could probably live with it. But this is very random and definitely offbeat and has a "digital noise" sort of sound. I just checked the most recent occurrence and it happened when I was holding a long note. |
Are there any cfl light bulbs in the area? Those'll put out noise like crazy. I know I mentioned the tube before - see if you can get a new one and pop it in in place of the one already there. Even better before you do that or anything else - lose the Blue Tube and see what happens. The SansAmp - are you running off the internal battery or phantom power? |
Last night I recorded 4 takes with the identical setup and setting and had no pops. For the record, the CFL was off. I'm sure it was on when I had the last incident because it is only on during the day. Thanks for all the suggestions! |
And I'd get rid of that cfl and either go to a traditional bulb or an led bulb. CFL's create noise and when they break you're dealing with hazardous waste; as a matter of fact in most places when one dies it has to be treated as hazardous waste and not go in the regular trash. |
Thanks for all your help. It would appear that the CFL is the culprit, especially since this problem seems to crop up only when that's on. |
Any solution to random "Calculating Overviews" nuisance? | Tim R. | Pro Tools 10 | 2 | 07-24-2012 05:24 PM |
Random Error, missing iLok authorization for "Pro Tools 9" | ktuulu | Windows | 52 | 04-05-2012 09:53 PM |
Random "pre-midi notes" before real note | Mahkyb | macOS | 8 | 02-08-2012 06:36 AM |
Random short "pop" noise with Pro Tools MBox | johndkeene | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-15-2010 10:48 AM |
PT 8.1 audio "hits" or "pops" when i open files from PT7... | djoeyd77 | Pro Tools TDM Systems (Mac) | 1 | 10-31-2009 03:59 AM |
