Re: Is there a track limit with this app?
I also just tested in Cubase 7.5 and the problem is the same. 36 Tracks is the useable limit.
Well, another version of Cubase is out and another version of EuControl and still I have this problem!
Cubase 8.5 / EuControl 3.3.2 / Win 8.1 64Bit. I'm using an iPad 2 with iOS 9.1 in case that is relevant. I'm not that upset about not being able to run this app as it is now BUT I own an S3 and the Avid Dock looks like quite an appealing product. It appears to be based around a more developed version of this app so I hope to find a solution somehow. Is anyone running this successfully with Cubase and Windows? Last edited by J-S-Q; 12-08-2015 at 04:30 PM. |
Can you say if these tests were done on Windows?
Would love to get an answer to the above question. Has the app been tested with Cubase on Windows by Avid, or anyone on this forum?
If it works then I will spend time troubleshooting it and maybe getting hold of a different generation iPad. Just want to know if ANYBODY is using it successfully with large track counts? |
Well... Not sure if it's the fact that I have a different wireless router, that I'm on Windows 10 or that I've upgraded to Cubase 8.5.1 but this seems to be working fine now regardless of track count.
Thanks for the support on this Avid. :) |
#16
I too now get the error withe the avid dock. was there a fix?
#17
Hi, i've been trying to solve this issue but still no luck. But i've discovered you can have as many tracks as u want in Protools Control mixer view or channel view but when u want to change to track view you must be focused on the very last 8 banks of tracks of your project, before you switch to track view. If you do his then Track view wont crash cubase/nuendo. But the moment you try to navigate down to the other tracks in track view, it will crash Cubendo. Happens both in Win10 & OSX Yosemite.
@JSQ, can you navigate banks in track view after your system solved itself out? Thnx for any help |
#18
#19
Thnx JSQ, im stumped why i cant get it to work.
What brand/model of wifi router are u using? |
#20
https://www.upc.cz/pdf/manualy_inet/..._manual_v5.pdf This page has some info on the router I have: http://www.ispreview.co.uk/index.php...rget-voip.html Last edited by J-S-Q; 06-03-2016 at 03:22 AM. |
Pro Tools Track Limit | Freis968 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-03-2006 10:19 PM |
20 Track limit | Cayotic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 31 | 06-09-2004 08:49 AM |
Track Limit | pwat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 10 | 05-11-2004 05:39 AM |
32 track limit? | David Abraham | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 03-25-2004 06:49 AM |
track limit | mentalmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 06-21-2002 04:41 PM |
