Old 02-18-2019, 10:13 AM
noiseboyuk noiseboyuk is online now
Default What was the name of that apparently magical dialogue plugin?
My memory...
I think it was out last year, based on a rare or custom bit of hardware. Helps it sit in the mix, one of those "just sounds right" things. Someone recommended it to me a while ago, can't remember who that was either... sigh... does the DUC hive mind know what I mean? All my search attempts have failed...
Guy Rowland
www.guyrowland.co.uk
www.sound-on-screen.com - Original audio clips of movies, TV shows and games, licensed as regular production music.
PT 2024 Ultimate; W11 Pro; Ryzen 9 7900; 64gb RAM; RME Babyface; UAD Quad Satellite USB; GTX 1050i
Macbook Air M2; 24gb RAM
Old 02-18-2019, 11:02 AM
reichman's Avatar
reichman reichman is offline
Default Re: What was the name of that apparently magical dialogue plugin?
You might be thinking of McDSP's SA-2, based on Mike Minkler's custom hardware. It's not magic, but I own it and use it.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 02-18-2019, 11:38 AM
Ah thank you Daniel, that's the one. Disappointed to hear it's not actual literal magic, but will demo it next week.
Guy Rowland
Old 02-20-2019, 07:30 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
Guy - it’s great. Highly recommended as the last layer of 800 sandpaper on your dials. Give ESV a call
cheers
Mike Aiton BSc (hons)
Audio Consultant, Dubbing Mixer/Sound Designer & Journalist
BAFTA member
IPS member
www.mikerophonics.com
Old 02-20-2019, 09:38 AM
tom_lowe tom_lowe is offline
I got it and used it, but found even on its most gentle settings it turned S into F etc. What did I do wrong!?
Went back to Pro-DS
Old 02-20-2019, 09:46 AM
I don’t treat it as as a de-esser. I have Sonnox (surgical), fabfilter (general) and SPL (best for drama as it is not a side chain compressor and does it with phase - which seems to hurt dial least.) on my channels for that.
The SA-2 is a gentle mastering compressor for any unevenness on my channel premix HF content - and just smoothes everything nicely, like a dB or two of bus compression does to my slightly compressed source channels. If it is all roughly good, then this is a very fine nice ironing process that allows you to tailor your Hmf and Hf.
Just my 2C.....
cheers
BAFTA member
IPS member
Old 02-20-2019, 05:22 PM
philper philper is offline
The analogy to 800-grit sandpaper is right--it is a very nice tweak/secret sauce. You will make trouble for yourself if you try to use it as a regular heavy-lift de-esser....
Old 02-21-2019, 05:05 PM
Henchman Henchman is offline
I use a combo of TD Nova and Soothe.
www.markhensley.tv
IMDB Credit List
Living the dream.
Old 02-22-2019, 02:20 AM
Is that on the bus or each track? I do like Soothe
Old 02-22-2019, 04:09 AM
Just my 2C.....
Thanks Mike, that's good to know!
HTML code is On
Dialogue Timing Plugin indeloon85 AAX Plug-ins 0 03-17-2017 03:52 PM
PT 11 is Here, apparently! jryser macOS 0 04-07-2013 05:33 PM
32-bit, 4Gig cap. is apparently BS fenderrocker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 30 08-26-2009 11:28 PM
The Magical Bass Frequencies crs117 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 10-07-2004 03:22 PM
What do I need to do? Not looking for a magical answer, just an opinion ... lcouri 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 06-25-2001 07:10 AM
