Can Protools auto-match&sync audio and video with matching TC?
I edit this piece in FCPX. There was an urgent need to edit BEFORE I had a chance to sync dual system audio.
The question is: can I edit with camera audio and leave syncing of dual-system sound to the Protools sound editor? Meaning, can it be easily done? My audio and video clips DO have matching TC and unique filenames. Thanks! EDIT: there's way too many clips to sync manually in FCPX, as it doesn't have batch syncing. Sync-n-Link X is not an option now. Thanks for understanding. |
Re: Can Protools auto-match&sync audio and video with matching TC?
Yes if using the field recorder workflow.
But you better make sure you are absolutely right about everything you stated and that the sound editor knows how to do this. Otherwise you are just compounding a problem. It doesn’t matter if “people on the internet” know how to do this if your sound editor doesn’t. Talk to him/her.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Another reason to never ever use FCPX on anything more than a tiny simple video. Not a team player.
I have delivered many broadcast things with FCPX. AAF/OMF isn't a problem but this very time, we absolutely had to edit before being able to sync. It would probably be a very similar issue with Media Composer. Thanks though :)
Not wanting to hijack this thread but I have a project coming from a client editing on Final Cut Pro X and was wondering if it can create OMFs or AAFs.
Thanks Scott
Scott Auckland New Zealand PT2022.5 Focusright RedNET 8Pre, RedNET R1 Z690 AERO D Workstation, I7 3.6GHz 12 core, 64GB RAM, Win10 Business 64bit |
No. Not directly.
You need third party software
In order to use Pro Tools' Field Recorder workflow you MUST have at least 2 things matching in the metadata of the AAF audio and recorder files in order for the files to link up. And one of those 2 things must be the timecode. I am unaware if FCP X preserves metadata but you should do a test. If not, you may be able to export an XML from FCP and import it into ediload, which in turn will export a ProTools session that will allow you to match up the field recorder files.
You need X2Pro, and the resulting export is still a dog's breakfast. FCPX is not a tool for use on jobs where exchange with other depts (esp sound) is required. If you can finish within FCPX, then rock on. But the exports I've been getting from even well-meaning FCPX users are so time-consuming to unravel that I either charge extra if they insist on exporting from that app or I turn down the job altogether. The longer and more complex the sound track of a project is the more I have found this to be true. |
(other option is to send the FCP X to Logic Pro X and then use Logic Pro X to do the export of an AAF -- which it can do.)
Auto Match Pull Factors & 25fps to 24fps workflow | tj_davies | Post - Surround - Video | 4 | 03-05-2008 09:26 AM |
Auto Match Indicator | cubasteve | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 10-08-2007 10:55 AM |
"Auto Match Pull Factors" | lancebrwn | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-22-2003 10:37 AM |
ProTools and Video Sync | soma323brooklyn | Post - Surround - Video | 9 | 06-27-2003 11:55 AM |
ProTools and Video Sync | soma323brooklyn | Pro Tools TDM Systems (Mac) | 3 | 06-26-2003 12:28 AM |
