Old 08-22-2014, 05:40 PM
AirborneFO AirborneFO is offline
Default -6086 Error
Long time, no talk for me. Been busy with the Army life but have finally been able to get back to recording and have done quite a bit of upgrades to my system.
I am now on a iMac and running OSX. But a weird thing is happening. I am beyond 1000% positive I am recording to my external drive. It is the same drive I have always record to. Positive. If there is one thing I know, it's record to the external drive.
So why after only 2 tracks am I getting the old -6086 error......? Any thoughts?
iMac i5, Pro Tools 10.2, DIGI003 Command, Akai MPK49, Simmons SDK9
AKA: HoFo
"Yes, recording to the system drive is 99% likely THE main problem." sw rec
Old 08-23-2014, 03:47 AM
Stig Eliassen's Avatar
Default Re: -6086 Error
If you go to Setup (menu) > Playback engine; what is your CPU usage limit set to?
Old 08-25-2014, 03:18 PM
I usually keep at the default of 85%, 4 processor. IF....I start running into issues, I run it at no more than 256 Sample when I am recording, but bump up higher when recording. Never really ran into this issue before. For example....ran a brand new session with SSD4 and a SanAmp plug in. These were the only 2 tracks. Got a little in and it popped up -6086. Under System Usage for those 2 tracks, I am pulling 8% on the CPU (Native), so that shouldn't be the issue.
And here is the crazy part. I usually fight this for the first few tracks going. Obviously, as I add mono audio tracks, it will still pop up. But then the more i go, it almost seems as if it goes away. Then I'll pop a -90XX type error here and there, but usually will be fine as I go.
Thoughts?
AKA: HoFo
Old 08-26-2014, 02:54 AM
Are you running PT 10.2 now?
I would start with Deleting Pro Tools Databases and Preferences.
4 processors is max for your computer, right? Try setting it to 3.
Also, do you have Ignore Errors During Playback/Record checked in the Playback engine? I get a better performance out of PT on my iMac by leaving this option off, but I can't explain why that is.
Old 08-26-2014, 08:10 PM
Yep, trashing preferences was the first thing I did. Jumped up to OSX, so researching a bit that may be some of the issue. For whatever reason, my Xpand2 disappeared as well.
However.....lol.....3 core and ignore and no issues yet. We'll run a bit and see. Plus need to figure out the Xpand thing now. LOL!
AKA: HoFo
Error -6086 Heatrize 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2012 11:14 PM
Error -6086 fix. dannydog 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 04-24-2012 04:03 AM
DAE error -6086 temetrepo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-30-2006 07:39 PM
6086 error Joemanuk 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-07-2006 11:37 AM
Help with Error (-6086) xlrsound General Discussion 1 02-06-2006 07:14 PM
