Old 08-19-2014, 11:10 AM
SteveH44 SteveH44 is offline
Default V10.3.9 Logic Corruption
As a normal rule, we do not install revisions the minute they come out, but I felt since 10.3.9 had been out for some time, it should be mature enough to install - wrong! We have 14 workstations at this facility, had installed 10.3.9 for TDM on 3 machine, and instantly had calls from the control room with problems. 1st the input button on the channel strip does not work, meter movement shows signal, but no output. Selecting record ready does allow audio to be heard. So it would there is a logic issue with this version.
Rolling back software to version 10.3.5 corrects problem. I'm sure going to v10.3.8 would also correct problem as well. Error seems confined to 3.9.
Spec's: Mac Pro 2.66G, 16G RAM, OSX 10.7.5, currently PT 10.3.5.
Thanks in advance
Old 08-19-2014, 02:54 PM
Chief Technician's Avatar
Chief Technician Chief Technician is offline
Post Re: V10.3.9 Logic Corruption
It's a known issue. v10.3.8 does not have this problem. Input Monitoring doesn't work in Pro Tools HD 10.3.9
Jonathan S. Abrams, CEA, CEV, CBNT
Apple Certified - Technical Coordinator (v10.5), Support Professional (v10.6 through v10.10)
Old 08-20-2014, 06:02 AM
Default Re: V10.3.9 Logic Corruption
Thanks for the reply. Sorry to be redundant. Interesting that Avid hasn't pulled it down. Isn't really just a minor annoyance.
CORRUPTION UP THE #@!$ Josiah LE Pro Tools TDM Systems (Mac) 6 08-18-2007 11:33 AM
Session Corruption spaceman Pro Tools TDM Systems (Mac) 2 04-03-2006 03:21 AM
Bounce corruption MartinHughes 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 05-20-2005 03:12 AM
Timeline corruption Cliff Hughes Post - Surround - Video 2 12-24-2003 08:49 AM
9.2.1 possible disk corruption Park Seward 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 10-09-2001 01:01 PM
