Old 08-19-2014, 03:12 PM
anackman's Avatar
anackman anackman is offline
Default Preventing iLok Auth While Opening PT
I bring my iLok to another studio outside my house a few times a week for sessions, so I can access certain personal plugins of mine while working from there.
When I am not there, how do I prevent Pro Tools from asking for ilok authorizations when booting up? In other words, I don't want other engineers and producers to be bothered by those messages when opening their sessions (of course they won't have the ilok authorization because the plugins are mine). But, I would like to have my "special" plugins available to me in the plugin folder when I am there. If I put the plugins in the "unused folder," then they are not there for me. I can't figure out how to make this system work.
Example: all my Sonnox plugins ask for authorization if the iLok is not plugged in when opening Pro Tools. I am the only engineer who has Sonnox plugins and we don't have the the authorizations for Sonnox at the studio, unless I bring my iLok.
Thanks.
10.11 OSX El Capitan
PT 12.4
Mac Pro Quad Core (Studio) + Mac Mini (Home)
UAD Apollo Duo
UAD Satellite Quad
Old 08-19-2014, 03:37 PM
Default Re: Preventing iLok Auth While Opening PT
The only way to prevent this would be for you to drag the Sonnox plugins out of the plugins folder when you leave.(create a spare folder so you have an easy path for dragging to/from). The other solution would be for the studio to buy the plugins
Old 08-19-2014, 04:28 PM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Smile Re: Preventing iLok Auth While Opening PT
To follow up on what Dave said, you could do something like this...
1 - Create a folder somewhere on the mac (Desktop, Documents, whatever is easy for you to get to), or on your own hard drive if you bring one with you to the studio.
2 - Name it whatever you want, like My Stuff
3 - Create an alias inside that folder for each of these 2 folders:
Macintosh HD/Library/Application Support/Avid/Audio
Macintosh HD/Library/Application Support/Digidesign
Now you have your own folder with these alias folders, which contain these 4 subfolders:
AAX Plugs:
Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins
Macintosh HD/Library/Application Support/Avid/Audio/Plug-Ins (Unused)
RTAS/TDM Plgs:
Macintosh HD/Library/Application Support/Digidesign/Plug-Ins
Macintosh HD/Library/Application Support/Digidesign/Plug-Ins (Unused)
The easiest way (IMHO)) to create an alias is to highlight a folder or file like "Audio" or "Digidesign" in the example above, hold down Command+M, and drag to the location where you want to create the alias.
I don't go to that much trouble on my own system, but I've always found it useful to drag the Pro Tools folder from /Applications/Avid to the sidebar in the Finder window. Makes it quicker for me to get to the AAX Plug-Ins and DPM Plug-Ins alias folders located there.
Also, I always have "Show path bar" enabled in the Finder > View settings. Makes it easier to navigate to a parent folder by clicking on it at the bottom of the Finder window. You can also add the "Path" option to the Finder toolbar using Finder > View > Customize Toolbar or by right-clicking on the toolbar in a Finder window.
Just some options, whatever works for you.
Bruce Paine
System Details
Kontakt 5 preventing PT 10.3.2 from opening musicman691 macOS 1 11-14-2012 12:34 PM
Plugin auth weirdness - guest iLok prevents internal iLok? Scott Helmke VENUE Live Sound Systems 3 09-07-2011 07:06 AM
No iLok auth... woogs Pro Tools 9 5 03-04-2011 04:02 PM
Transfer iLok auth. from old iLok to new 003 factory iLok? lamp 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-20-2007 07:05 PM
ilok auth backwards compatibile - PT7.3 auth run 7.2? Barnaby Bristol Post - Surround - Video 2 06-20-2007 09:30 AM
