MC Pro Workstation&Video-switching
I own a v1 (silver) MC Pro for about a year now, and I'd like to extend it's possibilities with the on-board video-switching system.
Will the following components work together in order to make the MC Pro switch video sources when switching workstations? - Keyspan USA 19-HS - Gefen 4x1 DPKVM Has anyone got tips or recommendations on this? Thanks! Niek/ Amsterdam.
Pro Tools Ultimate 2023.6 / Nuendo 12 / Logic X / WaveLab 11 MacPro 5.1: 12Core 3.46GHz Intel Xeon/ 48GB RAM/ Mac OSX 10.14 MacBook Pro: 2.9 GHz Intel Core i9/ 32 GB RAM/ Mac OSX 10.14 MetricHalo ULN8 + 2882 / RME HDSPe MadiFace Euphonix MC Pro |
Re: MC Pro Workstation&Video-switching
I think it should work. I saw that the gefen you mentioned has also a serial adapter so this you connect to the keyspan which is connected to your 5-mc usb port. don't forget to install the proper keyspan USA 19-HS drivers on your 5-mc.
for more information look here: http://connect.euphonix.com/document..._Switching.pdf
Best Thomas Pro Tools HDX 3 / Pro Tools HD 6 (TDM) 4 x 192, 2 x SSL Delta Links, MTRX/SPQ/Dante Avid S3, Euphonix 5MC All variations of Mac's, PC's and Coffee Machines... |
Sounds great, thanks for your tips Thomas, much appreciated!
Niek/ Amsterdam.
You're very welcome!
You need the Ontrak ADU200 USB Relay I/O Interface and the correct Gefen model. See the doc above for info.
Thanks too Eddie,
does this mean my v1 MC Pro only works with the Ontrak and only with the recommended video-switchers? I read in the Avid document called "MC Installation" http://cdn.avid.com/MCPro_EUCON/2.7....stallation.pdf , on page 7: "On MC systems with multiple workstations, you can switch display and keyboard control between workstations. The MC uses a Keyspan USB-to-serial adapter to control a KVM (keyboard/video/mouse) switch with a serial connector. This setup will allow relay switching of up to four inputs to a single output on a DVI/KVM switcher (such as the Gefen eX-Tend-It series)". Now, I'm a bit confused; does only the Ontrak do the job, or the Keyspan as well? Niek/ Amsterdam.
I'm sorry you are total right, we added the Keyspan to it a while back and the system detects what you have connected (Keyspan or Ontrak) and uses it. V1 and v2 can use either.
Thanks Eddy,
Quite a relief while obtaining an Ontrak here in The Netherlands is not easy. Niek/ Amsterdam.
Gefen 4-port Displayport-switchers are not available any more unfortunately.
http://www.gefen.com/kvm/ext-dpkvm-4...?prod_id=10026 Does anyone know if the Gefen 2-port Displayport-switchers will work? http://www.gefen.com/kvm/ext-dpkvm-241.jsp?prod_id=8689 Or the Blackbox AVSW-DP4X1A ? This switcher listens to Ascii codes 1 thru 4 ...... http://www.blackbox.nl/nl-nl/fi/1465...ayPort-Switch/ Thanks! Niek/ Amsterdam.
Pro Tools Ultimate 2023.6 / Nuendo 12 / Logic X / WaveLab 11 MacPro 5.1: 12Core 3.46GHz Intel Xeon/ 48GB RAM/ Mac OSX 10.14 MacBook Pro: 2.9 GHz Intel Core i9/ 32 GB RAM/ Mac OSX 10.14 MetricHalo ULN8 + 2882 / RME HDSPe MadiFace Euphonix MC Pro Last edited by niekbeem; 01-20-2016 at 01:18 AM. |
The Gefen 2 port should work. I'm not sure about the Blackbox.
AVID WAKE UP! Switching from Pro Tools to Studio One Instructional Video Released | Ghost In The Attic | General Discussion | 10 | 08-10-2015 10:04 AM |
Structure the Songwriter's Workstation Video | RussUK | Virtual Instruments | 0 | 07-02-2009 03:45 PM |
switching to PC, question about video playback | vudoo | Pro Tools TDM Systems (Win) | 2 | 03-28-2009 05:32 AM |
Advice on buying a new Audio/Video Workstation… | rogerhavoc | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 08-11-2003 12:54 AM |
MAC, PC or Workstation? | Ricky Ricardo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 12-13-2001 05:17 PM |
