Control Panel and Pro Tools show different buffer size (latency).
Mbox 3 pro
Win 7 64bit Intel cpu with Nvidia motherboard (yes I know this is bad, but it has worked before without issue.) 1. Open new session, add tracks, record, add plug-ins. No Problem. close session for the day. Come back next day and I hear a major delay when recording. No preferences or anything were changed. Just shutting down computer and starting the next day. 2. My Mbox control panel in general setup shows my Buffer size (latency) as 128 but in my playback engine in pro tools it shows 256. I can not make them the same. If I change my buffer size in pro tools the control panel changes to the option just under the pro tools buffer size. Ex. 512 in PT and 256 in control panel. I can make the PT 64 and the control panel 64 but I get audio artifacts and I still get noticeable latency from my input device. 3. My playback often stops working and if i check the minimize additional I/O latency box i get sound again. Then it will cut out after I am editing or mixing and then I check the box again and the sound comes back. So wierd. I have also done a lot of research and made my rig very PT friendly. At least as much as possible without getting a new computer. Here is my sandra report. Please help!!! ***** Start of Report ***** -------------------------------------------------------------------------------- <<< Computer Overview >>> -------------------------------------------------------------------------------- < Computer > Model: EVGA 132-CK-NF79 Serial Number: 1 Chassis: EVGA Desktop Mainboard: EVGA 132-CK-NF79 Serial Number: 1 BIOS: Phoenix Technologies, LTD 6.00 PG 03/15/2008 Total Memory: 6GB DIMM SDRAM < Processors > Processor: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2C 3GHz, 6MB L2) < Chipset > Memory Controller: nVidia nForce 790i Host Bridge 4x 333MHz (1.33GHz) FSB Memory Controller: nVidia MCP55 Memory Controller 2x 1.67GHz (3.33GHz) FSB, 6GB DIMM SDRAM 1GHz < Memory Module(s) > Memory Module: OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module: OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) Memory Module: OCZ OCZ3G1600LV2G 2GB DIMM DDR3 PC3-8500U DDR3-1066 (7-7-7-16 4-26-8-4) < Video System > Video Adapter: NVIDIA GeForce GTX 470 (448 SM5.0 1.22GHz, 1.3GB 3.35GHz 320-bit, PCIe 2.00 x16) Video Adapter: NVIDIA GeForce GTX 470 (448 SM5.0 1.22GHz, 1.3GB 3.35GHz 320-bit, PCIe 2.00 x16) < Graphics Processor > OpenCL GP Processor: NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz/ 1.22GHz, 1.3GB 3.35GHz 320-bit) Compute Shader Processor: NVIDIA GeForce GTX 470 (448SP 1.22GHz/1.22GHz, 1.3GB 3.35GHz 320-bit) CUDA GP Processor: NVIDIA GeForce GTX 470 (448SP 14C 1.22GHz/ 1.22GHz, 1.3GB 3.35GHz 320-bit) < Storage Devices > Seagate ST3200822A (200GB, ATA:186GB (G:) (H:) WDC WD2500AAJS-00B4A0 (250GB, :233GB (C:) (E:) WDC WD1500AHFD-00RAR1 (150GB, :140GB (D:) WDC WD15EADS-00P8B0 (1.5TB, SA:1TB (Z:) PIONEER DVD-RW DVR-112D (622.:594MB (I:) < Logical Storage Devices > Downloads (G:): 146GB (NTFS) @ Seagate ST3200822A (200GB, ATA100, 3.5", 8MB Cache) Reserved (E:): 100MB (NTFS) @ WDC WD2500AAJS-00B4A0 (250GB, SATA300, 3.5", 7200rpm, 8MB Cache) Downstack (D:): 140GB (NTFS) @ WDC WD1500AHFD-00RAR1 (150GB, SATA150, 3.5", 10000rpm, 16MB Cache) Archives (Z:): 1TB (NTFS) @ WDC WD15EADS-00P8B0 (1.5TB, SATA300, 3.5", 32MB Cache) Files (H:): 40GB (NTFS) @ Seagate ST3200822A (200GB, ATA100, 3.5", 8MB Cache) Boot (C:): 233GB (NTFS) @ WDC WD2500AAJS-00B4A0 (250GB, SATA300, 3.5", 7200rpm, 8MB Cache) Audio CD (I:): 0bytes (CDFS) @ PIONEER DVD-RW DVR-112D (622.7MB, ATA66, DVD+-RW, CD-RW, 64kB Cache) < Peripherals > LPC Hub Controller 1: nVidia MCP55 LPC Bridge LPC Legacy Controller 1: Winbond W83627DHG Audio Device: nVidia MCP55 High Definition Audio Audio Codec: Realtek Semi 888 High Definition Audio Audio Device: EVGA GF100 High Definition Audio Controller Audio Codec: nVidia Mutara V08 [NV2] Audio Codec: nVidia Mutara V08 [NV2] Audio Codec: nVidia Mutara V08 [NV2] Serial Port(s): 1 Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia nForce 790i Memory Controller Disk Controller: nVidia MCP55 Memory Controller USB Controller 1: nVidia MCP55 USB Controller USB Controller 2: nVidia MCP55 USB Controller FireWire/1394 Controller 1: nVidia TSB43AB22 1394a-2000 OHCI PHY/Link- Layer Controller SMBus/i2c Controller 1: nVidia MCP5 SMBus 1 SMBus/i2c Controller 2: nVidia MCP5 SMBus 2 < Printers and Faxes > Printer: Microsoft XPS Document Writer (600x600, Colour) Printer: HP Deskjet 3050A J611 series (600x300, Colour) Printer: HP Deskjet 3050A J611 series (600x300, Colour) Fax: Microsoft Shared Fax Driver (200x200) < Scanners and Cameras > Scanner: Hewlett-Packard HP Deskjet 3050A J611 series (NET) (Scanner, USB) < Network Services > Network Adapter: NVIDIA nForce 10/100/1000 Mbps Ethernet (Ethernet, 100Mbps) Network Adapter: NVIDIA nForce Networking Controller #2 (Ethernet) < Operating System > Windows System: Microsoft Windows 7 Home 6.01.7601 (Service Pack 1) Platform Compliance: x64 < Windows Experience Index > Current System: 5.9 <<< Processor Arithmetic >>> -------------------------------------------------------------------------------- < Benchmark Results > Aggregate Native Performance: 25.44GOPS Dhrystone Native ALU: 31.54GIPS Whetstone Native SSE3: 20.52GFLOPS Results Interpretation: Higher Scores mean Better Performance. Decimal Numeral System (base 1:1GOPS = 1000MOPS, 1MOPS = 1000kOPS, 1kOPS = 1000OPS, etc. < Performance per Thread > Aggregate Native Performance: 12.72GOPS Dhrystone Native ALU: 15.77GIPS Whetstone Native SSE3: 10.26GFLOPS Number of Threads: 2 Results Interpretation: Higher Scores mean Better Performance. Decimal Numeral System (base 1:1GOPS = 1000MOPS, 1MOPS = 1000kOPS, 1kOPS = 1000OPS, etc. < Performance vs. Power > Processor(s) Power: 52.940W Aggregate Native Performance: 480.49MOPS/W Dhrystone Native ALU: 595.71MIPS/W Whetstone Native SSE3: 387.55MFLOPS/W Results Interpretation: Higher Scores mean Better Performance. < Performance vs. Speed > Aggregate Native Performance: 8.48MOPS/MHz Dhrystone Native ALU: 10.51MIPS/MHz Whetstone Native SSE3: 6.84MFLOPS/MHz Results Interpretation: Higher Scores mean Better Performance. < Windows Experience Index > Current Processor(s): 6.6 Results Interpretation: Higher Scores mean Better Performance. < Benchmark Status > Result ID: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2C 3GHz, 6MB L2) Computer: EVGA 132-CK-NF79 Platform Compliance: x64 SMP (Multi-Processor) Enabled: Yes NUMA Support: No Number of Threads: 2 Processor Affinity: C0T0 C1T0 System Timer: 2.93MHz Number of Runs: 64000 / 640 < Processor > Model: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed: 3GHz (100%) Minimum/Maximum/Turbo Speed: 2GHz - 3GHz Peak Processing Performance (P:24GFLOPS Adjusted Peak Performance (APP:7.2WG Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Dual-Core L1D (1st Level) Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 (2nd Level) Cache: 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing < Features > SSE - Streaming SIMD Extension:Yes SSE2 - Streaming SIMD Extensio:Yes SSE3 - Streaming SIMD Extensio:Yes SSSE3 - Supplemental SSE3: Yes SSE4.1 - Streaming SIMD Extens:Yes < Performance Enhancing Tips > Tip 223: CPU speed, under load, lower than rated speed. Check power management settings. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. <<< Multi-Core Efficiency >>> -------------------------------------------------------------------------------- < Benchmark Results > Inter-Core Bandwidth: 3.13GB/s Results Interpretation: Higher Scores mean Better Performance. Binary Numeral System (base 2):1GB(/s) = 1024MB(/s), 1MB(/s) = 1024kB(/s), 1kB(/s) = 1024 bytes(/s), etc. < Benchmark Results > Inter-Core Latency: 39.0ns Results Interpretation: Lower Scores mean Better Performance. Decimal Numeral System (base 1:1s = 1000ms, 1ms = 1000µs, 1µs = 1000ns, etc. < Performance per Thread > Inter-Core Bandwidth: 1.57GB/s Number of Threads: 2 Results Interpretation: Higher Scores mean Better Performance. Binary Numeral System (base 2):1GB(/s) = 1024MB(/s), 1MB(/s) = 1024kB(/s), 1kB(/s) = 1024 bytes(/s), etc. < Performance vs. Power > Processor(s) Power: 52.940W Inter-Core Bandwidth: 60.60MB/s/W Results Interpretation: Higher Scores mean Better Performance. Inter-Core Latency: 7.37ns/W Results Interpretation: Lower Scores mean Better Performance. < Capacity vs. Power > Total Cache Size: 117.26kB/W Results Interpretation: Higher Scores mean Better Performance. < Performance vs. Speed > Inter-Core Bandwidth: 1.07MB/s/MHz Results Interpretation: Higher Scores mean Better Performance. Inter-Core Latency: 0.13ns/MHz Results Interpretation: Lower Scores mean Better Performance. < Windows Experience Index > Current Processor(s): 6.6 Results Interpretation: Higher Scores mean Better Performance. < Detailed Results > Processor Affinity: CPU0-CPU1 1x 64bytes Blocks Bandwidth: 519MB/s 4x 64bytes Blocks Bandwidth: 649MB/s 4x 256bytes Blocks Bandwidth: 1.86GB/s 4x 1kB Blocks Bandwidth: 3.71GB/s 4x 4kB Blocks Bandwidth: 5GB/s 16x 4kB Blocks Bandwidth: 9.1GB/s 4x 64kB Blocks Bandwidth: 13.08GB/s 16x 64kB Blocks Bandwidth: 13GB/s 4x 1MB Blocks Bandwidth: 13GB/s 8x 1MB Blocks Bandwidth: 1.85GB/s 16x 1MB Blocks Bandwidth: 1.47GB/s 8x 4MB Blocks Bandwidth: 1.5GB/s < Benchmark Status > Result ID: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz (2C 3GHz, 6MB L2) Computer: EVGA 132-CK-NF79 Platform Compliance: x64 Buffering Used: No Number of Threads: 2 SMC (Multi-Core) Enabled: Yes Cores per Processor: 2 Unit(s) System Timer: 2.93MHz Page Size: 4kB < Processor > Model: Intel(R) Core(TM)2 Duo CPU E8400 @ 3.00GHz Speed: 3GHz (100%) Minimum/Maximum/Turbo Speed: 2GHz - 3GHz Peak Processing Performance (P:24GFLOPS Adjusted Peak Performance (APP:7.2WG Cores per Processor: 2 Unit(s) Threads per Core: 1 Unit(s) Type: Dual-Core L1D (1st Level) Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size L2 (2nd Level) Cache: 6MB, ECC, Synchronous, ATC, 24-way, 64 byte line size, 2 threads sharing < Performance Enhancing Tips > Warning 5010: Cannot use Large Memory Pages due to lack of privileges. Tip 223: CPU speed, under load, lower than rated speed. Check power management settings. Tip 2: Double-click tip or press Enter while a tip is selected for more information about the tip. <<< Media (Audio/Video) Transcode >>> -------------------------------------------------------------------------------- << HD TV (H.264 1280x720/30p @ 4Mbps; AAC 2x 16-bit @ 192kbps) >> << Hardware Accelerated >> Error (346): Transcoding failed. Use software transcoding or check transcoders installed. << Software >> << Full HD TV (H.264 1920x1080/30p @ 8Mbps; AAC 2x 16-bit @ 256kbps) >> << Hardware Accelerated >> << Software >> << HD Streaming (H.264 1280x720/30p @ 2Mbps; AAC 2x 16-bit @ 128kbps) >> << Hardware Accelerated >> << Software >> << SD TV (H.264 720x480/30p @ 3Mbps; AAC 2x 16-bit @ 128kbps) >> << Hardware Accelerated >> << Software >> << Embedded (H.264 480x320/30p @ 1.5Mbps; AAC 2x 16-bit @ 128kbps) >> << Hardware Accelerated >> << Software >> << Phone/Player (H.264 320x240/15p @ 500kbps; AAC 2x 16-bit @ 96kbps) >> << Hardware Accelerated >> << Software >> -------------------------------------------------------------------------------- ***** End of Report ***** |
Unsupported audio buffer size in device control panel | TheVRsNo$ | Windows | 27 | 12-09-2019 06:28 AM |
Buffer size in PT different than on soundcard panel | mdb | Pro Tools 9 | 0 | 08-13-2012 12:30 PM |
Latency issues (pro tools and control panel show different values...) | birdfluvirus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 06-24-2012 10:22 PM |
Digi001 doesn't show up in XP Sound Control Panel | MaizeBass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-06-2002 07:07 PM |
H/W Buffer Size panel does not work | PaulVanGelder | Digidesign Hardware & Software | 1 | 11-02-2000 05:06 AM |
