Re: 2 midis together?
Either that or post the session file for us to look at? |
http://i1142.photobucket.com/albums/...T_screen_2.jpg It has 2 instrument tracks and 2 midi tracks. (I added 2 midi tracks, but no difference) How do I post session file? (Could I e-mail this?) If you would post working "session file" with 2 diff instruments and 2 different midi controllers, I could load it up on my system, and see how its done. Is this possible? |
I think I know what the problem is. I see in your previous post you said:
Also, did you install the KeyStudio 25 drivers? I'm not sure that it should show up as an O2 - that's usually reserved for the Oxygen series, though they could share a driver. In any case - you should see a USB input for that keyboard available and that's what should be selected for the other Instrument tracks MIDI input. I've posted a session file that works, though I don't know how it will open up or if it will show anything useful since you don't have the exact same keyboards (I used a Axiom Pro 49 and an Axiom 25). 2 MIDI Inputs session file |
Alternately you can email it to me at : vi [at] digidesign [dot] com. |
#16
2. Keystudio-25 uses O series driver (No Changes) 3. Changed Axiom Pro from hypercontrol to USB A Couple things I noted. You have Default Thru Instrument None, and mine will not produce any sound with this (I had to change it to Follows first selected Midi Track). Also noted your second Instrument uses "Port 1" (In Midi Input Selector) I cannot find "Port Settings" on my setup. I am using MobilePre USB Hardware, and both my usb keyboards connect directly to computer via USB. Since I am unable to select Thru Instrument to NONE, I bet this is what the problem is. Using 64bit win7 with 8.0.4cs2. |
#17
#18
I'm unable to do this too with the same version on Win XP.
Model : Intel(R) Core(TM)2 Quad Q6600 2.40GHz IDC : 4x 32kB, Synch, Write-Thru, 8-way, 64 byte L2 : 2x 4MB, ECC, Synch, ATC, 16-way, 64 byte line sz, 2 thds sh Mainboard: DFI Inc. INF P35-R BIOS : Phx Tech, LTD 6.00 PG 03/11/2008 Bus(es) : ISA X-Bus PCI PCIe IMB USB i2c/SMBus MP APIC : Y Tot Mem : 3.25GB DIMM DDR2 (WinXP) Chipset: Intel P35/G33/G31 Proc Front Side Bus Spd : 4x 266MHz Mem Bus Spd : 2x 399MHz (C:) : (250GB, SATA, 8MB Cache) (D:) : (250GB, SATA, 8MB Cache) |
#19
Getting close
When I select record enable (clicking the red button)I can now hear the instrument, when I have "Default Thru Instrument set to None". But I am unable to select multiple instruments as "record enable" ie only one instrument is enabled at a time. I know this is some simple command.... tried it with Ctrl and selecting tracks. (I can select multiple tracks, but it still wont record enable multiple tracks, just one) Cant wait.... Found it on my own Simple.... but it took like over 2 weeks. Thanks for your help. To enable multiple track record enable: Select all the tracks you want to affect, then hold shift + option while you arm the tracks. Works great now. |
#20
Actually you should only need to hold down shift when clicking to record enable multiple tracks.
A Tale of Two MIDIs... | RegisWhite | Pro Tools 11 | 7 | 09-02-2013 08:37 PM |
