Old 03-13-2018, 02:32 PM
jazzmonger jazzmonger is offline
Default PT 12.8.1 and Command 8 - stopped working?
Everything was working great, or so I thought. Came in to mix my latest project and my Command 8 quit working. I've tried everything, even went back and tried it on my old PC running PT 12 and it works just fine.
Interestingly, I cannot select "Port 1" for input to PT. I can select Port 1 for output to the C8, but for input to PT it only shows "Port 2", which from everything I've read is NOT the USB port, its the 1st MIDI port. Disconnecting literally everything on my system (Mac PRO 2013) and I can still only see Port 2 in all MIDI apps Including MIDI Tools.
In Audio/MIDI Setup it shows the little pic of the Command 8 and all 3 ports are listed there with port 1 showing both a MIDI In and an Out.
Its a little achedemic at this point because I've tried everything and ordered a new FaderPort16 as a replacement.
I honestly don't think it has anything to do w/ PT. If other MIDI apps dont see Port 1, it has to be my Mac, and knowing how to fix it would be awesome. Esp for a diehard PC\hardware guy who is now in love with BOTH my Macs, even though sometimes they cause me grief just because they are way too simple and I don't get to reboot all the time in the middle of recording sessions!
Jeff
Old 03-13-2018, 08:13 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: PT 12.8.1 and Command 8 - stopped working?
Trash prefs and try again
Daniel
Old 03-13-2018, 08:17 PM
Mac Prefs? How? I dont think this is a PT issue.
Old 03-13-2018, 08:22 PM
YYR123's Avatar
Sorry I thought I read it was academic, I must have misunderstood.
Daniel
Old 05-12-2018, 06:59 PM
SKI's Avatar
SKI SKI is offline
Jeff
So how's that FaderPort working out for you?
URBAN MUSIC-
(Hip Hop and R&B)
Old 06-12-2018, 09:59 AM
ToneSetter ToneSetter is offline
I'd also like to know how the faderport is working for you
Old 03-14-2019, 12:45 PM
BenningtonCollege BenningtonCollege is offline
Ugh. This same thing just happened to me. Under MIDI interfaces, where I normally select Command 8, Receive Port 1, Send Port 1, 8 channels it offers nothing under Receive, but still has Send options. Helllllp!
Jeff
Old 03-14-2019, 01:12 PM
Hey! This worked! I got my Command 8 back.
Here's how to trash Preferences on a Mac:
Open a finder window, and click the Go menu. Hold down the Option key and Library appears as a selection.
Under Library go to Preferences.
Delete the following files: com.digidesign.ProTools.plist
com.digidesign.ProTools.plist.lockfile ( I didn't have this.)
DAE Prefs folder
DigiSetup.OSX. Pro Tools Prefs
Restart Protools and Go to Set Up, Peripherals, and the third tab is Midi Controllers. Use the Pull Down menus to select:
Thanks, Guys n Gals!
Import not working + Drag & Drop Stopped working royalg333 Pro Tools 11 1 06-08-2016 01:02 PM
Video Window just stopped opening + Crossfades stopped working [SOLVED] DBK macOS 0 02-28-2015 12:34 AM
PRO TOOLS 8LE was working on windows 8, stopped working after 8.1 update... Jon Vandenbor 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-01-2015 02:10 PM
Command 8 Faders just stopped DJElBee Post - Surround - Video 6 09-30-2011 11:03 AM
Command - period.... stopped working! huh? imi 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-26-2001 05:47 AM
