Old 10-18-2012, 03:18 PM
dalehannegan dalehannegan is offline
Default "Auto Read" grays out when recording- cant monitor while recording HELP
First of all, here is the gear:
PT 10.2
Mac Book Pro
Focusrite Liquid Saffire 56 Interface
This problem just started happening. I'm trying to record bass direct into my saffire. I select the analog input 4 which is a designated 1/4 inch instrument jack on the saffire, output is Mon 1-2 like normal. Whenever I press record, the "auto read" button grays out and I cannot hear the input signal coming out of my monitors. The signal is going in per the fader signal and it does record, but I cannot get actual sound from my monitors while recording. Once I stop recording the "auto read" turns green again.
All other tracks do the same thing
Automation is enabled
I can hear all other tracks playing while I'm recording except the enabled (recording) track
I have Googled to no avail. I can use the Saffire mix control to set up a headphone mix, but it's complicated. I prefer not to use it.
Any help would be greatly appreciated.
Wrong "auto-rating" of clips during loop recording joachim Pro Tools 11 5 02-10-2015 11:58 PM
"recording" or making a "tempo track" using tap tempo music project 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 10-12-2013 04:42 AM
ERROR MESSAGE : "Could not allocate space for recording! " when recording audio. Save|The|Architect 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 8 01-03-2011 10:04 AM
"access violation " protools can not make auto backup " nachonieto 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-16-2008 03:54 PM
Is there a way to have "AUTO TALKBACK" engaged WITHOUT "Dim" happening? The Zone ICON & C|24 4 10-21-2008 06:03 PM
