"Clear..." key command not working
I've recently begun using PT 9.0.1 on my Macbook Pro (10.6.6) in addition to my tried-and-true HD rig. On the Macbook Pro, I can not get the "Clear..." command to execute via key command (⇧⌘B). The "Select Unused" command (⇧⌘U) works fine, but I must use the menu under the regions list to complete the "Clear..." command.
Anyone else seeing this? |
Re: "Clear..." key command not working
Ray Trujillo Freelance Audio Engineer |
I should have mentioned that I checked into this first and found that there is a default key command in OSX (Send File to Bluetooth Device) but it was not enabled. I also went as far as deleting this service's key command and rebooting but the PT "Clear..." command is still not available. |
No problems with it here on 9.0.1 on several rigs. I use that key command a lot, so I'd notice if it stopped working.
Are any of your rigs Macbook Pro? I also have access to many different systems, but the Macbook Pro seems to be the only one with this problem.
Is anyone out there running PT 9.0.1 / OS 10.6.6 on a MacBook Pro and experiencing this problem?
So after 5 months of trying to get this to work (as well as upgrading to 10.6.7 and PT 9.0.3) I still can not get the ⇧⌘B (Shift+Command+B) to clear selected regions on my Macbook Pro.
Is there ANYONE else using PT9 on a Macbook Pro who can confirm or deny that this is a bug? |
Cannot open PT9 Session in PT10 - ""could not complete the open sessions command..." | median | Pro Tools 10 | 5 | 10-01-2013 11:14 AM |
Does "Westmere" qualification apply to "Bloomfield" and "Gulftown" also? | bashville | Pro Tools 10 | 5 | 03-23-2013 03:04 PM |
Clear parameters after "Write Realtime Midi....." | Bushpig | Pro Tools TDM Systems (Mac) | 1 | 05-30-2011 02:48 PM |
hardware buttons for "preview", "capture" and "punch" | evs | Post - Surround - Video | 1 | 12-06-2010 12:28 PM |
New 27" imac / "original" mbox - need some clear advice.please help !! | santococo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 05-21-2010 10:30 AM |
