Keycommand help PC
All the "secret" keycommands are missing in the keyboard shortcuts PDF?
I just rediscovered an old page from sound on sound that lists some helpful keycommands and i was thinking ok, maybe iīll learn something. Oh yes, i have been stuck with the same workflow for ages, not helping myself to some new information to speed things up. Anyways, there was one that was particularly interesting, itīs the first one on the page: http://www.soundonsound.com/sos/sep0.../keypoints.htm To turn automation on, Ctrl+Option+Command-click (PC: Ctrl+Start+Alt-click) on the plug-in parameter. To switch that track to display automation data for a given parameter, Ctrl+Command-click (Ctrl+Start-click) on the plug-in parameter. Ok so i Ctr+Start+Alt click on the what? Plugin automation enable is not plug-in parameter? When i press the plug-in automation enable button holding Ctr+Start+Alt All the parameters in the pluginwindow gets pink/red outlines and then what. I donīt get it, could someone please explain to me what i am missing out on, because i donīt get the: "To switch that track to display automation data for a given parameter, Ctrl+Command-click (Ctrl+Start-click) on the plug-in parameter." to work.
PC 7980XE @ 4.2 PT 12.7 Ableton 10.0.1 Great River ME-1NV, Ehrlund EHR-M, Axiom Pro 49, Brauner Valvet, Oktavamod MXL-910, RODE NT5 with Oktavamod MJE-384K, Crane Song Trakker, SSL 611EQ, SSL X-Desk, Sennheiser HD600/650 IS Pro Double 6" Speakers, www.intelligentsound.se/ |
Re: Keycommand help PC
Ctrl+Start+Click on the plug-in parameter. Then select "Enable Automation for...". After that, you can just Ctrl+Start on the same parameter to quickly display the automation play list in the Edit window.
On that subject, this shortcut should definitely not open a new window with two user choices. That's absolutely ridiculous and definitely doesn't qualify it as a shortcut. It should directly enable the plug-in parameter invoked by the command. If someone needs to go to the plug-in automation window, they can click on the icon for it. Also, Ctrl+Start should display the plug-in parameter in the Edit window and enable the parameter if it wasn't already enabled. This area was not well thought out and I'd love to chat with the individual who makes these final decisions to implement, as it appears they spend little time in actually using Pro Tools. Quote:
On that note, some PT commands have been changed over the years. A few commands in PT 8 have strayed away from their original sequence which makes the fluid easy work flow the PT once had no longer, as it continues to bloat up over time with no user defined key commands. Hope that helps and clarifies things. Shane
Pro Tools Power User Editing Give your plug-ins a facelift...and skin 'em! __________________ "Music should be performed by the musician, not by the engineer." Michael Wagener 25th July 2005, 02:59 PM __________________ Pro Tools|HD Native 9.0.1 | Pro Tools|HDX 10.2 | Studio One | REAPER 4.22 | HD OMNI | HoboMac Pro 2.26Ghz Quad-Core | W7 Ultimate 64-bit |
Quickly reading through your answer gave me nothing, but hey, itīs way past bedtime here in Sweden and iīll read it again tomorrow with PT on and hopefully most of my braincells too.
Thanks for your reply! =)
Shane
Ok i get it, this only applies for digis own plugins, i was trying to use this command for 3rd party plugins with no success.
Is there a way to solve this, because the keycommand is really valuable.
Shane
GenMTC Keycommand | TCLguy1 | Pro Tools TDM Systems (Mac) | 0 | 09-18-2009 09:04 AM |
Keycommand to toggle plugin-settings? | dpclarkson | Pro Tools TDM Systems (Mac) | 2 | 05-18-2009 12:49 AM |
Keycommand for changing plugin presets...? | FredrikThomander | Pro Tools TDM Systems (Mac) | 0 | 08-30-2004 12:45 PM |
Keycommand for "Display Waveforms Rectified?" | PeeTee | Tips & Tricks | 2 | 11-03-2000 11:59 AM |
