Old 01-30-2008, 07:41 PM
mistasmijen mistasmijen is offline
Default Time shifting/pitch shifting?
I cant quite figure out how to use these to tools. I dont see them in the inserts window on the track list, however they are up on the top of the screen, in a drop down menu. (cant think of the name of it right now)
When i open it up, i get a bunch of settings, but i cant figure out how to assign it to a track or sample. Could someone point me in the direction of a tutorial, or help me out?
Thanks
Old 01-31-2008, 03:24 AM
Phil Ogden Phil Ogden is offline
Default Re: Time shifting/pitch shifting?
That's because these are Audiosuite plug-ins only. Processing is done offline. Simply
1. Highlight the region you want to process.
2. Select the plug in from the Audiosuite drop down menu.
3. Make the changes to the settings.
4. Process. If the 'use in playlist' tab is highlighted (top right), the processed region will replace the original in the edit window.
Further information is contained in the plug-ins reference guide, available via the help PT menu.
http://www.myspace.com/philogg
Time Stretching/Pitch Shifting/Auto-tuning, etc. blastula Pro Tools TDM Systems (Mac) 11 07-24-2007 07:55 PM
Pitch Shifting danika 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-05-2007 07:15 PM
Pitch Shifting Add - On SamuelAdams 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-09-2006 11:09 AM
Pitch shifting - Time compression program. GtrDude 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 01-07-2004 12:26 AM
25-24 fps pitch shifting. Does anyone know? Kenan Akkawi General Discussion 1 07-23-2001 04:10 AM
