Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
  #21
Old 01-10-2018, 12:59 PM
simonjewel's Avatar
simonjewel simonjewel is offline
Default Re: How old is your DAW computer?
Originally Posted by Ben Jenssen View Post
I've had it running for a couple of months now, and it's as stable as anything since OS X 10.2! Feels as snappy and smooth as ever.
The only two things I've not been able to solve is hardware related: my Apogee FW Duet have occasional minuscule clicks, and it seems my graphics card (original ATI Radeon HD 2600 XT 256) have occasional dropouts lasting a second or less. Both these things are so rare that I can live with them no problem on my home everyday mac. When I boot from my SnowLeopard (for PT10) or Lion partition, they go away.
It won't upgrade, until someone makes a new installer with a new patch. I tried upgrade from the App Store and it refused because of hardware incompatibility.
I've not been able to retrace where I got it from.
I'm afraid I can't remember the exact details of the installation, I thought that there might have been more to it than just running the installer from another disk, like some custom procedure, but now I'm not shure. I still have the .dmg with which I installed sierra. 5.5GB, and no accompying special instructions. Very unlike me to not archive those, if they existed.
So I checked; I just now mounted the dmg, opened the installer (it was in norwegian as I am that), and it checked my mac's compatibility, OK'ed it and everything was ready to install. So I'm pretty shure that if you have a mac pro 3.1 and run this installer, it will read in english, and it will work.
Now, if you would suggest a way to make this 5,5GB available to you, I would be more than happy to do so. (Like, WeTransfer free has a 2GB limit…)
Thanks Ben!! I'll look into it and PM you if that's ok?
  #22
Old 01-10-2018, 01:04 PM
Ben Jenssen's Avatar
Shure.
  #23
Old 01-10-2018, 01:23 PM
EGS's Avatar
EGS EGS is offline
Originally Posted by musicman691 View Post
One of the best bets for preemptively taking care of things is to have a good ups/power filtering system...
+1 for a good ups/power filtering system. Also:
*use only high quality components in the first place
*excellent cooling
*humidity/temperature controlled room
*no overclock
*periodic cleaning/dusting
*replace battery
*don't bang it around too much
*multiple backups of everything, incl system drive
Even so, eventually everything breaks.
I'm asking about typical expected lifespan/failure rate of:
*motherboard
*power supply
*CPU
*RAM
*video card
I googled - didn't find much.
Thanks !!!
Click for audio/video demo
Click for resume
  #24
Old 01-10-2018, 01:26 PM
simonjewel's Avatar
Shure.
I had a quick look on the net to see if there was any way to install High Sierra on older Mac Pro's and found this
https://www.macworld.co.uk/how-to/ma...r-mac-3654960/
I thought it might be of interest to others also Ben, if you wanted to change to High Sierra.
  #25
Old 01-10-2018, 04:23 PM
*excellent cooling
*no overclock
*replace battery
*motherboard
*power supply
*CPU
*RAM
*video card
Thanks !!!
The gist of what I wrote and to a certain extent what you wrote if you adhere to those precepts then life expectancy will outlive the ability to support the operating system needed to run future s/w.
A temp/humidity controlled room went away a long time ago.
There is no 'typical' lifespan of the components you're asking about. The term you're looking for is MTBF - meantime between failures. And that depends on what the manufacturer says and what they consider a failure. One may give a number based on total failure while another may give a number based on specification degradation but the device still works.
In short you're going to have to ask each manufacturer.
Jack
QAPLA!
  #26
Old 01-10-2018, 04:52 PM
jryser's Avatar
jryser jryser is offline
2012 and 2013 MacBookPros - the '13 is the master and just upgraded to all SSD sample libraries - upgraded VEP to 6, staying on PT 11, Yosemite, and all is right in the world. I get 5 more years I'll be beyond thrilled! It should outlast me anyway!!!
A Rig: MacBook Pro Spring 2013, 2.8Ghz I7, 16GB RAM,
OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph GT 050 Qx3 1.5 TB drives Thunderbolt-FW400, Presonus Faderport. 10 REMOVED!
B Rig:MacBook Pro Spring 11, 2.33 GHz I7, 16GB RAM, OSX Mavericks 10.9.4, PT 11.2, MBox Pro 3, Glyph Portagig 62 portable 1 TB drive Firewired with 400, Presonus Faderport. 10 REMOVED!
I am the main songwriter/performer for Midwest Whitetail, Cabela's Deer Nation, Spring Thunder, and Northern Waters Series!
  #27
Old 01-10-2018, 05:41 PM
EGS's Avatar
EGS EGS is offline
temp/humidity controlled room went away a long time ago...
The term you're looking for is MTBF ...
I meant to say no temp or humidity extremes.
MTBF - thanks !!!
Well, Gigabyte claims the motherboard caps are good for 50,000 hours: "100% 50,000 hour lifespan Japanese solid capacitors design". So, I guess I'm good for a while!!!
Click for resume
  #28
Old 01-10-2018, 06:07 PM
MTBF - thanks !!!
That's only one part - what about all the others? 50K hours might seem like a lot but that's only 5.7 years of 24/7 run time.
I figure that once I get past what's called 'infant mortality' then I'll be good UNLESS there's a known failure point like Apple had with certain iMacs and the video cards in them.
Jack
QAPLA!
  #29
Old 01-10-2018, 06:15 PM
clivvy clivvy is offline
2008 mac protools HD11 native card yosemite still going strong no need to change!
  #30
Old 01-10-2018, 06:47 PM
EGS's Avatar
EGS EGS is offline
Good point!!! Hey, what do you think of this (old) article?https://www.pcworld.com/article/2028...-hardware.html
Click for resume
Computer experts have you heard of this computer maker? garnoil General Discussion 3 07-07-2013 06:05 PM
Migrating to new computer and want to transfer my presets to new computer???? MASTERLINKSTUDIOS Pro Tools TDM Systems (Mac) 2 10-23-2008 10:52 AM
Digi 001 computer out to computer Cable Question dbguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 08-28-2004 03:29 PM
Desktop Computer or Network Computer? platinumx99 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 12-07-2001 08:04 AM
question : can i copy/paste all my computer hard/soft to other computer . for a gig. sandman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-10-2001 08:38 PM
