Avid Pro Audio CommunityHow to Join & Post • Community Terms of Use • Help Us Help YouKnowledge Base Search • Community Search • Additional Resources |
Hi All,
Anyone using the Quartet for 5.1 monitoring? I haven't purchased it yet and was wondering how well it works with PT. Thank you. |
Are you using the Apogee Quartet or the Avid Quartet? Avid includes an I/O Control software that makes the 5.1 setup easier. Just wondering if it's worth it.
Thanks. |
![]() Quote:
Apogee includes their own IO software, just set up 1-6 accordingly, and setup a 5.1 in the PT IO. Actually very easy. AFAIK, Avid Quartet IO software is the same. https://www.avid.com/~/media/avid/fi..._userguide.pdf The only upside to Avid Quartet is Windows compatibility. Which I don't need. So I went with Apogee so I can record VO on my iPhone or iPad. Using it with a 2012 Mac Mini Quad, when I bring home sessions. 32 tracks, a bunch of eqs,compressors, limiters, and RX dialog noise reduction. While pushing DNXHD36 video. I have PT12HD auth, as I also have an Omni HDX rig, so I can't tell you if Vanilla PT allows a 5.1 bus, or output. FIY Apogee will not respond to support requests on the Avid version.
IMDB |
![]() Quote:
Thanks. |
![]() Quote:
Maestro software is Apogees IO configurator, yes you install it, configure it once, 1 to 1 2 to 2 3 to 3 4 to 4 5 to 6 to 6, and it runs on boot. Then you configure the Protools IO for 5.1 As you stated: "Avid includes an I/O Control software that makes the 5.1 setup easier." Its the same as Apogee's software, Apogee calls it "Maestro".
IMDB |
Apogee Quartet | Xcurve | FireWire and USB Audio Interfaces (Mac) | 0 | 05-10-2017 11:54 AM |
Pt 11 & Apogee Quartet | sankstone | Pro Tools 11 | 3 | 04-12-2015 12:19 PM |
Quartet Hardware | 87echo | Pro Tools | Duet & Pro Tools | Quartet | 2 | 09-17-2014 07:02 AM |
Recording a string quartet - how many mic? | gonglee | Tips & Tricks | 3 | 05-13-2004 07:01 AM |
another quartet question ? | surchur | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 05-16-2003 08:27 AM |
