Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Duet & Pro Tools | Quartet
Old 10-18-2014, 03:52 AM
Recyourmind Recyourmind is offline
Default Pro tools io control. Panel doesn't show up on windows
Any suggestions. Duet works records. Can't get the the setting where the 48hz. Or anything.
Old 10-18-2014, 03:54 AM
Default Re: Pro tools io control. Panel doesn't show up on windows
New this this forum any help would be great
Old 10-18-2014, 07:49 AM
VRW VRW is offline
Not quite sure what´s the problem or if I´m getting it right.
Anyway.
Sorry, if I´m getting it wrong but do you mean with "on windows" the OS?
Probably not as the Duet is only made for Mac and you say that it does record actually...
Secondly you need to install Apogee Maestro 2 software which is the "place" where you
set up your input/record levels, the monitor mix and also the sample rate (44.1KHz or 48KHz).
http://www.apogeedigital.com/support/duet-2
http://www.apogeedigital.com/support/duet-ios-mac
As mentioned before I´m not sure to have got it right but I have tried it anyway.
The best of success,
VRW
Mac Mini i7Quad, 16GB Ram, MBP Mid 2012 2,5GHz i5, 16GB Ram, MacOS 10.10 Yosemite, Apogee Quartet+Duet 2, Genelec Active,
Yamaha NS10, Pro Tools 11.2.1, Logic 10.0.7, Waves, MCDSP, Duende Native, Softube, HOFA, IK Multimedia, NI etc.
Old 10-19-2014, 10:21 PM
I have the new pro tools duet bundle works for windows and Mac no maestro. The app is called pro tools io control. But the control panel or app isn't showing up only the drivers and firmware updater
Old 10-19-2014, 10:22 PM
It's works. Getting playback. Records fine. Just can't get to that application
Old 10-20-2014, 01:11 AM
VRW VRW is offline
Ah, ok.
All the best.
Old 10-23-2014, 11:56 AM
donnydonny's Avatar
donnydonny donnydonny is offline
In the Start menu, it is listed in its own folder called "PT IO Control Panel."
Donny
Avid Community Team
Old 10-28-2014, 10:48 PM
not there theres one in the avid folder but no app
Old 10-29-2014, 12:01 AM
Bruce Paine Bruce Paine is offline
Admin Emeritus
Have you tried downloading and reinstalling the latest version of the drivers?
Pro Tools | Duet & Pro Tools | Quartet Drivers
Linked from the main drivers page at www.avid.com/drivers
Bruce Paine
System Details
Old 08-13-2015, 09:57 AM
Lightzy Lightzy is offline
I have the exact same issue.
I cannot control my card at all, as there is simply NO SUCH THING as the Pro tools IO Control on my computer (after having installed the latest drivers).
Using windows 8.1
Where the hell is this interface???
EDIT:
Ok, I did what any PC user should have done in the first place, gone to "program files (x86), to Avid, to the controller directory, and there it is.
But really, why is AVID so damn amateourish?! Do they not test their own **** even on THIS level?? To make sure that when you install something you get a desktop shortcut or something?
They have no idea how to do anything properly for windows
New 002/003 driver control panel doesn't draw properly Mike Harrison 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-18-2013 12:51 PM
Latency issues (pro tools and control panel show different values...) birdfluvirus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 06-24-2012 11:22 PM
Control Panel and Pro Tools show different buffer size (latency). birdfluvirus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 05-10-2012 10:11 PM
Digi001 doesn't show up in XP Sound Control Panel MaizeBass 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-06-2002 08:07 PM
001 inputs don't show up in sound control panel jghere 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-02-2001 10:28 AM
