#21
Re: Best possible hard drive configuration
Practically speaking - SSD won't be ready for DAW's anytime soon - even technically speaking you do as much writing as reading working in a DAW. So the whole technology isn't really 'audio workstation' friendly even as a 'design'. Kind of like the limitation of the original EIDE/ATA drive technology in comparison to SCSI where SCSI could read and write at the same time and EIDE needed to do one or the other. We audio guys could only really consider SCSI as a serious hi track count read/write medium for DAWs. The same is true now of SATA (drives with platters) versus SSDs. SSDs aren't the 'right' technology for DAWs -- yet.... .. Where they are very practical is for sample libraries that will very rarely need any 'write passes' but only ever need to be 'loaded' into RAM. That's the perfect application for SSD's -- currently.
Rig 1-Mix/Mast: PTHD 11.3.1; MacPro 6core (6,1) 3.5 GHz Xeon E5; 10.10.3 (SSD Drives for audio); Apogee DUET, FireStudio2626 as Hware Inserts to PT for outboard Rig 2-Cutting&Remotes: PTHD 11.3.1; MacBook Pro (8,1) 2.8 GHz Dual i7; 10.9.2 (128GB int '6G' SSD drive); Profire LightBridge (FW800), 32ch Presonus Digimax FS |
#22
I record on my internal sata drives but not my system drive. One drive for system, one drive for audio, and one drive is for sample libraries and if you move your samples you will just have to point your kontact or whatever software to find the moved library and it should remember where they are from then on out. External hard drives are slower and a little more of a pain.
Too many peripherals connected to the FireWire bus can cause problems as well. Then I have a two terabyte USB 2 drive for backups. If Im not using the internal drives I just un mount them with disk utility. I usually record at 88.2 24 bit. My system has been pretty solid. I just updated to 9 and the new Mbox pro. The sound / clock is a nice step up from my 002. |
#23
I will add that it's a bit of a myth to think you need your sample libraries on another drive. They're read only and load into RAM so they'd never interfere with your system drive's operation or access in any way -- unless of course you fill it up to much.. and violate the 25% free space rule for system drives.
#24
Most sample library manufacturers strongly recommend putting them on a separate drive, and say so in their support documentation. Certain libraries rely more on disk streaming, making this even more important. BFD2 and Synthogy Ivory are 2 such libraries.
#25
I've had nothing but trouble using the internal sata drives for recording(Avid even lists track limitations of them and last I check they're lower than approved Firewire 800 track counts).
I use 2 internal drives(one for system/apps and one for streaming of all of my sample libraries). For recording its only Glyph 050Q via FW800. Lastly, I keep a Drobo that I do a chronosync backup to every evening as well as using separate cloned 050Qs for each specific project. Hard drives die, you have to be prepared and set yourself up to suffer no downtime in case of those situations. At present, this setup is as good as I've seen in terms of usability, track count, speed, and lack of errors BUT that being said it's still far from a perfect art. I really hope the SSD industry brings pricing down and DAW mfgs do whatever is necessary to provide better compatibility with the new drives. Given that its 2011 and also where current hardware technology is I don't know why we're still working under the limitations of 5 years ago in terms of actual hard drive compatibility & function. |
#26
But still, 10% or greater is all you need. That is the limit Apple sets.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Hard drive configuration | fat_fish | Pro Tools M-Powered (Win) | 1 | 08-10-2006 06:45 AM |
Hard drive configuration | fat_fish | Pro Tools M-Powered (Win) | 1 | 08-09-2006 05:04 PM |
? on hard drive configuration | deejfro | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 09-07-2005 07:12 PM |
Hard Drive Configuration | Zetajazz44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2004 02:38 PM |
Hard Drive Configuration | souelle | Storage Subsystems | 0 | 02-12-2003 06:54 PM |
