Go Back   Avid Pro Audio Community > General Discussion & Off Topic > General Discussion
Old 02-02-2009, 08:20 PM
Abdul Aziz Abdul Aziz is offline
Default Problem with recording vocals in Pro Tools 8
Hello to all,
I was recording vocals to track when all of a sudden, the vocals wouldn't sync
to track, the vocals were going to track slightly behind the music tracks-and then I started getting an error message telling me to remove some plug-ins and/or increase the buffer size. Can someone tell me how to resolve this issue so that I can stop getting these error messages, and get my vocals to track in time with the music tracks. Thanks!
I'm running my Pro Tools LE Mbox2 w/Triton Extreme Workstation-Sampler, all into my Mac Book Pro 2.4 GHz, 4 GB SDRAM
Last edited by Abdul Aziz; 02-02-2009 at 08:31 PM. Reason: I forgot and left out my system info.
Old 02-03-2009, 06:52 PM
O.G O.G is offline
Default Re: Problem with recording vocals in Pro Tools 8
If I follow you correctly, go to the set up tab in Pro Tools, and select " Playback engine". From there, Increase the Buffer Size until you are not getting any latency. Im a rookie, But I think this may help. And you also my wanna watch the instructional DVD that came with your purchase of Pro tools. It covers a lot of the basics. Hope this helps.
Old 02-27-2009, 05:00 AM
miek07 miek07 is offline
Your it seems like your hogging too much CPU, deactivate parts you don't need to record vocals. Secondly, latency is related to sample rate and buffer size.. i would suggest you experiment with 256 and 512 sample buffer size.
michae
myspace.com/miekwavesoundlab
Static Problem when recording vocals Filmmaker123 macOS 0 10-20-2012 07:33 AM
Having a problem in Pro Tools when recording vocals musiclovin 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-09-2010 09:20 PM
Problem With Recording Vocals in Pro Tools Visceral 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 06-09-2009 04:44 AM
Problem with recording vocals in Pro Tools 8 Abdul Aziz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 02-02-2009 10:05 PM
Problem recording vocals!!!Help!!!Delay!! dmt2828 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-11-2007 12:14 PM
