? on hard drive configuration
I am currently running a WD 80g for my system drive, and a WD 200gig for my sessions and sound banks. would I see any benefit by partitioning the 200g drive in half and using one for sessions and the other for sound banks? and also...just reconfirming that I am supposed to have the audio files for each session in the session folder right?
thanks Jeff PT6.9 amd 64 3400 k8v se dlx 1gig micron mbox |
Re: ? on hard drive configuration
Just for clarity, sound banks as in for a soft synth and the WD drives are IDE Parallel ATA 100 hard drives, correct ...
I personally have my sound banks on my native/system drive, I am not sure if there is a right or wrong place to put those, but to me it would seem to be quicker to have them on the drive that contains the rest of the instrument's programing ... but, that could be is just me. The only real way to get an improvement in hard disc preformance would be to get better performing hard drives ... SATA drives and WD's Raptor SATA drives inparticular seems to be the big thing. You could still use your 200 Gb WD as Storage but SATA drives are much quicker ... 150mbps, where as most IDE are 100mbps and SATAs have faster seek times as well. I use SATAs as both my native/system and audio drives (right now I am using two Seagate 80 Gb Barracudas and two 80 Gb WD's in mobile trays as storage) I would also like to suggest putting all your drives in moblile racks. It makes it much easier to replace if something goes wrong. The trays make storage more conveinent ... You can have a larger main back-up of your system in one place. They make transportation a bit easier, as well and I could go on, but won't ... but that's my $0.02 and I hope it helps ...
were humans involved ... if so, I can believe almost anything! |
Yeah Thanks...not that I'm having problems with the current set...just always looking to make things better...
jeff |
Best possible hard drive configuration | Whasssaaahhh | macOS | 25 | 01-01-2011 04:11 PM |
Hard drive configuration | fat_fish | Pro Tools M-Powered (Win) | 1 | 08-10-2006 06:45 AM |
Hard drive configuration | fat_fish | Pro Tools M-Powered (Win) | 1 | 08-09-2006 05:04 PM |
Hard Drive Configuration | Zetajazz44 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-21-2004 02:38 PM |
Hard Drive Configuration | souelle | Storage Subsystems | 0 | 02-12-2003 06:54 PM |
