Old 05-11-2017, 12:09 PM
Xcurve Xcurve is offline
Default Quartet 5.1 Monitoring
Hi All,
Anyone using the Quartet for 5.1 monitoring? I haven't purchased it yet and was wondering how well it works with PT. Thank you.
Old 05-12-2017, 01:16 PM
TVPostSound's Avatar
TVPostSound TVPostSound is offline
Default Re: Quartet 5.1 Monitoring
Does 5.1
I use the PT12HD, routes as it should.
IMDB
Old 05-12-2017, 06:44 PM
Originally Posted by TVPostSound View Post
Does 5.1
Are you using the Apogee Quartet or the Avid Quartet? Avid includes an I/O Control software that makes the 5.1 setup easier. Just wondering if it's worth it.
Thanks.
Old 05-12-2017, 11:33 PM
Thanks.
Apogee branded.
Apogee includes their own IO software, just set up 1-6 accordingly, and setup a 5.1 in the PT IO. Actually very easy.
AFAIK, Avid Quartet IO software is the same.
https://www.avid.com/~/media/avid/fi..._userguide.pdf
The only upside to Avid Quartet is Windows compatibility. Which I don't need.
So I went with Apogee so I can record VO on my iPhone or iPad.
Using it with a 2012 Mac Mini Quad, when I bring home sessions. 32 tracks, a bunch of eqs,compressors, limiters, and RX dialog noise reduction.
While pushing DNXHD36 video.
I have PT12HD auth, as I also have an Omni HDX rig, so I can't tell you if Vanilla
PT allows a 5.1 bus, or output.
FIY
Apogee will not respond to support requests on the Avid version.
IMDB
Old 05-19-2017, 10:07 AM
Apogee branded.
My Sweetwater rep says I will need to run the Maestro software with PT in order to have the master volume control all of the 5.1 outputs. Is this true?
Thanks.
Old 05-20-2017, 10:17 AM
Thanks.
He's making it sound more than what it is.
Maestro software is Apogees IO configurator, yes you install it, configure it once, 1 to 1 2 to 2 3 to 3 4 to 4 5 to 6 to 6, and it runs on boot. Then you configure the Protools IO for 5.1
As you stated:
"Avid includes an I/O Control software that makes the 5.1 setup easier."
Its the same as Apogee's software, Apogee calls it "Maestro".
IMDB
Apogee Quartet Xcurve FireWire and USB Audio Interfaces (Mac) 0 05-10-2017 11:54 AM
Pt 11 & Apogee Quartet sankstone Pro Tools 11 3 04-12-2015 12:19 PM
Quartet Hardware 87echo Pro Tools | Duet & Pro Tools | Quartet 2 09-17-2014 07:02 AM
Recording a string quartet - how many mic? gonglee Tips & Tricks 3 05-13-2004 07:01 AM
another quartet question ? surchur 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 05-16-2003 08:27 AM
