What are the most common problems with Digi 001?
Here is my setup:
Intel PIII ,933MHz 256 Mb ram Windows Me SBLive Value sound card Intel 810e chipset American Megatrends BIOS 20 Gb internal hard drive Will I have any problems with Digi 001 rig? thanks in advance, geetarbill |
Re: What are the most common problems with Digi 001?
In theory it looks like it will work....
but they said that about Communism too.
electrobank 2+2=5 |
MOBO and CPU specs seem fine. Are you overclocked? 7200RPM Drive? DMA Enabled?
Off the subject: I use an Sb Live in conjunction with my DIGI and it work like a dream. I assume you will route the output of your SBLive into DIGI channels 3 and 4? I would suggest buying Higher quality shielded cables as the SB can generate a lot of noise. Same thing applies if you wish to connect a set of outputs from the Digi I/O box back into your SB card.
electrobank 2+2=5 |
If you can afford it, get a secon Hard drive where you will store all your working files that are not system related (protools session files, audio files ...)
------------------ Rock Da Sound!
Rock Da Sound! |
Pro Tools 9 Technical FAQ - Solutions to common problems | DigiTechSupt | Pro Tools 9 | 2 | 09-26-2011 03:30 PM |
What's the most common PT problems and their solutions? | JonesH | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 09-10-2011 10:38 PM |
Common Problems? Sample Rate!! | zeroclip | Pro Tools M-Powered (Win) | 1 | 02-15-2006 05:43 AM |
Very common problems with X and LE 6. | nessein | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 11-20-2003 04:44 AM |
Help with common Digi Plug-Ins | hkpwnetd | Pro Tools TDM Systems (Mac) | 4 | 03-19-2001 06:23 AM |
