Old 05-27-2013, 09:49 AM
DonaldM's Avatar
DonaldM DonaldM is offline
Default Reason, Reaper and AAX
I'm a bit confused on the relationship between Reason and PT and Reaper and PT with respect to AAX. I use both Reason and Reaper on instrument tracks in PTs and use the Rewire feature in each to route audio back to audio or aux tracks in PT for mixing. It all works just fine and everyone plays nicely with each other...usually.
What I'm unclear about is that I can't seem to locate any info that says that Reason is RTAS or AAX compatible. Same for Reaper. Currently I am using the 32bit versions of both with PT10. Will both work okay with the 64bit versions with PT11? I'm not seeing direct info on that. I've searched both the Propellerhead website and Reaper, but either I'm not looking in the right place or using the wrong search terms.
So, will my Reason 7 and Reaper 4.4 still work on an instrument track in PT 11 as now? From what I can tell, PT doesn't treat Reason and Reaper with Rewire as an RTAS or now AAX plug-in...is that correct?
"Never believe anything you hear in a song." Tyrion Lannister, Game of Thrones
Owner: Dragon Rock Productions LLC
Old 05-27-2013, 11:26 AM
YYR123's Avatar
YYR123 YYR123 is offline
Default Re: Reason, Reaper and AAX
I suppose we should be seeing a AAX version of rewire when PT11 drops
Daniel
Old 05-27-2013, 12:56 PM
Top Jimmy's Avatar
Rewire is neither RTAS nor AAX. It is not a plugin, but a virtual audio/MIDI interconnection protocol that allows the passing of data between two hosts, one acting as the mixer and the other as the instrument.
Buttdialed by me & Tapatalk
James Cadwallader
Old 05-28-2013, 04:06 AM
And before anyone asks Rewire is now 64 bit (actually has been for a while now). So that's one hurdle we won't have to worry about.
Jack
QAPLA!
Old 05-28-2013, 05:31 AM
DonaldM's Avatar
So does that mean that neither Reason nor Reaper need to be AAX then? Or, to put it another way, is it correct to say that PT doesn't see either of them as a plug-in even though they sit on an instrument track, but rather treats them both as Rewire hosts?
And speaking of Rewire - I've wondered for a long time why Rewire only runs 1 way. Why can't audio and/or MIDI data be sent both to and from the Rewire host? I've never understood that restriction.
Old 05-28-2013, 08:38 AM
Top Jimmy's Avatar
That is correct.
The restriction exists because Rewire devices come in two types, mixer and instrument. When you load Reason or Reaper in Pro Tools, PT is the mixer and the others are instruments. Hence the directions of signal flow.
James Cadwallader
Old 05-28-2013, 08:42 AM
More properly called master and slave although I like your terms better. But remember that Rewire slaves can contain instruments that go into the slave's mixer.
Jack
QAPLA!
Old 05-28-2013, 08:59 AM
Top Jimmy's Avatar
Originally Posted by musicman691 View Post
More properly called master and slave...
Hmmmm... Well, Propellerhead doesn't call them that. Technically, it's mixer and device, not instrument.
James Cadwallader
Old 05-28-2013, 10:11 AM
DonaldM's Avatar
That is correct.
Thank you for that explanation. Still, would be nice if it could be opened up so signal could be routed either way. There are times I wish I could send an audio signal TO Reason to use something like their Alligator or Pulverizer effect and then send it back to PT for the mix. Instead I have to export the audio clip from PT and reimport to Reason to add the effect I want. But at least I can use Rewire then to route the processed signal back into the PT mix. Oh well. Still a great thing!
Old 05-28-2013, 10:34 AM
Top Jimmy's Avatar
That's a trick that goes way back. When needing more tracks in early PT-LE, Rewire from Live Lite back to PT got more tracks in the mix.
James Cadwallader
HTML code is On
PT 11 with Reason and Reaper DonaldM Pro Tools 11 3 04-10-2013 07:11 AM
Question about 003 analog outputs used with Reason, Sampletank, Reaper, etc. DJ Hellfire 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 06-05-2010 11:30 AM
Pro Tools to Reaper... Need some help! DeyBwah 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 42 03-15-2010 08:24 AM
Reaper Rewire dave911 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 11 03-06-2010 11:00 AM
