increase H/W buffer size error
I have a intel i7 with EVGA x58 motherboard 6 gb ram, running vista home premium 32 bit with 1 hard drive for operating system (western digital 500gb) and a seagate 1.5 tb to save the music on. I am running a mbox2 mini with protools 8.0 LE
Everytime i run pro tools i set the track to record than master record, hit the space bar to record and BOOM right away i get the increase H/W buffer size error. So i go to play engine and increase/decrease no matter what size i have it set too this error pops up right away. it wont let me record at all. please help. |
Re: increase H/W buffer size error
Start here and post a Ssandra report. We need to know more about your sysytem. ...And welcome to the DUC.
Dgrim.....As a total noob with this program, I was having alot of the same problems you are. TOTALLY worth the effort going into the set up and doing EXACTLY as it says. I wasn't really sure that it was that important and kept fighting to try and get buffer space, h/d space, etc to work and it never did. Once you do EVERYTHING on the list......it works like a champ! It literally takes no more than probably 15 minutes to accomplish everything on the list. The biggest pain is the restarts, but again it's a 100% must do....
ok so i have done everything it said to do in the set up, i have tried using the windows drivers for my video card, i have installed the latest update from yesterday the cs3. i have tried using all different combinations in the play engine. changed the # of processors. i think i have tried it all and i still get the "operating system held off interrupts for too long error" i cant even record a track, play back anything, it just immediately pops up. i have a sandra report now and here it is. hopefully someone will notice something causing the problems. please help.
< System > Host Name: SCHORK-PC User: Schork Workgroup: WORKGROUP < Processor > Model: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz Speed: 2.65GHz Cores per Processor: 4 Unit(s) Threads per Core: 2 Unit(s) Type: Quad-Core Internal Data Cache: 2x 32kB, Synchronous, Write-Thru, 8-way, 64 byte line size, 2 threads sharing L2 On-board Cache: 2x 256kB, Synchronous, ATC, 8-way, 64 byte line size, 2 threads sharing L3 On-board Cache: 8MB, Synchronous, ATC, 16-way, 64 byte line size, 16 threads sharing < System > System: OEM OEM Mainboard: EVGA 132-BL-E758 Bus(es): ISA PCI PCIe USB FireWire/1394 Multi-Processor (MP) Support: 1 Processor(s) Multi-Processor Advanced PIC (:No System BIOS: Phoenix Technologies, LTD 6.00 Total Memory: 2.49GB < Chipset 1 > Model: EVGA ??? (3400) Front Side Bus Speed: 1x 133MHz (133MHz) < Video System > Monitor/Panel: ACER X193W (Analog) Adapter: NVIDIA GeForce 9400 GT < Physical Storage Devices > WDC WD5000AAKS-00A7B0 3.5" 500:465.76GB (C:) ST31500341AS 1500GB (SATA300, :1397.27GB (E:) ATAPI iHAP422 8 (ATAPI66, 48:N/A (D:) < Logical Storage Devices > Hard Disk (C:): 465.76GB (423.88GB, 91% Free Space) (NTFS) @ WDC WD5000AAKS-00A7B0 3.5" 500GB (SATA300, 7200rpm, NCQ, 16MB Cache) Hard Disk (E:): 1397.25GB (1397.12GB, 100% Free Space) (NTFS) @ ST31500341AS 1500GB (SATA300, NCQ) CD-ROM/DVD (D:): N/A @ ATAPI iHAP422 8 (ATAPI66, 48x CD-R, 48x CD-W, 6x DVD-R, 6x DVD-W, 2MB Cache) < Peripherals > Serial/Parallel Port(s): 1 COM / 0 LPT USB Controller/Hub: Intel(R) ICH10 Family USB Universal Host Controller - 3A34 USB Controller/Hub: Intel(R) ICH10 Family USB Universal Host Controller - 3A35 USB Controller/Hub: Intel(R) ICH10 Family USB Universal Host Controller - 3A36 USB Controller/Hub: Intel(R) ICH10 Family USB Universal Host Controller - 3A37 USB Controller/Hub: Intel(R) ICH10 Family USB Universal Host Controller - 3A38 USB Controller/Hub: Intel(R) ICH10 Family USB Universal Host Controller - 3A39 USB Controller/Hub: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A USB Controller/Hub: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Root Hub USB Controller/Hub: USB Composite Device USB Controller/Hub: Digidesign Mbox 2 Firmware Updater FireWire/1394 Controller/Hub: Texas Instruments OHCI Compliant IEEE 1394 Host Controller Keyboard: Standard PS/2 Keyboard Keyboard: HID Keyboard Device Mouse: HID-compliant mouse Human Interface: USB Human Interface Device Human Interface: USB Human Interface Device < Printers and Faxes > Model: Microsoft XPS Document Writer < Power Management > Mains (AC) Line Status: On-Line < Operating System(s) > Windows System: Microsoft Windows Vista Home Media Center 6.00.6001 (Service Pack 1) Platform Compliance: Win32 x86 < Windows Experience Index > Current System: 1.0 < Network Services > Adapter: Realtek RTL8168C(P)/8111C(P) Family PCI-E GBE NIC Adapter: Realtek RTL8168C(P)/8111C(P) Family PCI-E GBE NIC #2 |
anyone?????
disconnect your network services. you will probably be fine
Disable superfetch. Causes nothing but problems and lag. I had the same issues on Vista and couldn't record at 128 samples until I did that. Also, if you have itunes loaded make sure you disable Apple Mobile Device service. These 2 services kill ProTools right off the bat..
Curious. What's superfetch?
MBox2Pro / LE 8.0.5 |
There is a service that comes with Vista called Superfetch. I didn't even know about this until recently but apparently what it does it attempt to figure out what programs you use a lot and preload the software in the background so when you go to launch it it's faster. Really dumb in my opinion and really sucks up resources. I have Vista Home but I assume it's on all of them. You can disable by right clicking on my computer, go to manage and then drill down to services.
Increase buffer size Error.. -_- .. | changareth | macOS | 4 | 02-09-2011 08:50 AM |
increase H/W Buffer Size ERROR is Killing me | powerhouse0111 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 11 | 03-31-2010 11:51 PM |
Increase Buffer Size Error (Buffer at MAX) ??? | PoPimp3069 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 16 | 03-29-2010 02:24 PM |
Increase buffer size error | toddw | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 09-19-2008 02:05 PM |
Help! "Increase Buffer size" error | therigaletto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 02-17-2008 05:25 PM |
