Old 04-15-2015, 04:53 PM
ShiftStudios ShiftStudios is offline
Default Avid Application Manager System Usage
Good day,
Just curious if there are going to be any memory optimisations for the Application Manager.
As you can see from the below picture:
https://www.dropbox.com/s/i9axiz0nb9...Usage.png?dl=0
The only program using more memory than it's helper is my AV. Even the interface of the OS (Windows Explorer) and SQL Server don't use as much memory. Considering this app generally sits idle in the system tray, I'm not sure why the memory requirements are so high. I know in the big scheme of things, 70MB of memory is not a lot, but when you are trying to fine tune your machine down to bare minimum, and something that doesn't even get used uses more memory than something that is crucial to the operation of the system it makes you go hmmm.
Just an observation, and it would be nice to know if memory improvements are fourthcoming. :)
Old 04-16-2015, 07:20 AM
Benoni's Avatar
Benoni Benoni is offline
Default Re: Avid Application Manager System Usage
You can always turn it off from system start and just launch it manually when you want to see if there are updates or whatever. I have mine turned off, doesn't effect Media Composer or PT12 in my experience.
Brian
Windows 11 Pro | macOS 12
Pro Tools 2022
benonistudio.com
Youtube Channel - benonistudio
Plugin Deals
@benonistudio
Old 04-16-2015, 05:45 PM
Hi Benoni,
That's excellent news, I did not know that. Thank you!
Old 04-17-2015, 04:05 AM
Nish Nish is offline
Is the Application Manager the same as the one used for Media composer? For MC I have it turned of by default in my services just as a whole bunch other MC background services I don't want to be running all the time.
Thx
Application Manager stuck on "Connecting" and/or JREloadError Brado Pro Tools 12 61 02-19-2016 03:27 AM
Application Manager downloads rankinfile Pro Tools 12 11 01-01-2016 04:19 PM
Application Manager hooksound Pro Tools 12 0 04-08-2015 10:00 AM
