Old 03-07-2008, 07:24 AM
m00f m00f is offline
Default Clicks and Pops when recording Pro Tools M-Powered 7.4 CS3
HI
I am having problems with clicks and pops during recording.
I am using Protools M-Powered 7.4 CS3
M-Audio Delta 1010 with the latest drivers Delta_V32_5.10.00.5065.exe
I have a PC with a AMD dual core 64 X2 5000+ Processor
A gigabyte GA-MA69G-S3H Motherboard
2 gigabytes of ram
2 ide disc drives (1 system and one for audio data)
I have Windows XP Professional Service Pack 2 Installed
I have installed the Windows XP Dual Core Hotfix
I have installed the AMD Dual Core Optimizer
I have disabled AMD Cool n' Quiet in the bios
I have disabled my network card
I have installed quicktime
There are no devices connected to SPDIF
I have unticked the RTAS ignore Errors during playback/record (may cause clicks and pops) box
I have tryed various buffer size changes but nothing has made any difference
Protools will play back a session which was done at another studio no problems.
I can record into Soundforge with no problems!!
When I try to record into protools there are clicks and pops and crackles.
If i record silence it seems ok but when i sing or play guitar i have clicks and pops.
This is the first time i have installed protools.
I had an old copy of cubase before which was fine.
I have found these links which is similar to my problem
http://duc.digidesign.com/showflat.p...v=#Post1257672
http://duc.digidesign.com/showflat.p...part=1#1259635
but they are with 7.3 not 7.4
I'm needing some help
thanks..
Old 03-07-2008, 08:20 AM
DigiTechSupt's Avatar
Default Re: Clicks and Pops when recording Pro Tools M-Powered 7.4 CS3
You should start with the steps in the Win XP/ Pro Tools 6.x/7.x General Troubleshooting thread and post specific info on your system per the info on that thread if you're unable to resolve the problem.
Avid Audio Tech Support
Support FAQ
Old 03-11-2008, 08:29 AM
Hi
Yeah I have already worked my way thru the steps in the Troubleshooting guide.
As I mentioned in my post
Is there anything else that I might try?
I think my next step will be to reinstall Protools 7.3 as I have a vague recollection
of that working ok briefly before i upgraded to 7.4
I'll let you know how i get on.
M...
Old 03-11-2008, 08:55 AM
Yes, if you could post a Sandra report, as indicated in that thread, it would be greatly appreciated.
Support FAQ
Old 03-16-2008, 10:26 AM
soundmaster soundmaster is offline
you have no S/PDIF connected - so your sync-source is set to internal?
PT HD 9.0.6/Win 7 pro SP1 64bit/Q6600/EMU1820m
PT 9.0.6/HP 8560w/ProFire2626+Octane
Old 03-17-2008, 02:27 PM
Yeah the sync source is set to internal...
Old 03-17-2008, 02:30 PM
Sandra report below this is the computer overview part... there is another 4mb of the report with all sorts of stuff on there...let me know if there is any other information that you need to look at... thanks....
<<< Computer Overview >>>
< System >
Host Name: VISTIC-CR0UOKRY
User: vistic
Workgroup: WORKGROUP
< Processor >
Model: 1x AMD Athlon(tm) 64 X2 Dual Core Processor
5000+
Speed: 2.61GHz
Model Number: 5000
Cores per Processor: 2 Unit(s)
Threads per Core: 1 Unit(s)
Type: Low Power, Dual-Core
Internal Data Cache: 2x 64kB, Synchronous, Write-Back, 2-way, 64
byte line size
L2 On-board Cache: 2x 512kB, ECC, Synchronous, Write-Back, 16-
way, 64 byte line size
< System >
System: Gigabyte Technology Co., Ltd. GA-MA69G-S3H
Platform Compliance: AMD LIVE!
Mainboard: Gigabyte Technology Co., Ltd. GA-MA69G-S3H
Bus(es): ISA PCI IMB USB FireWire/1394 i2c/SMBus
Multi-Processor (MP) Support: 2 Processor(s)
Multi-Processor Advanced PIC (:Yes
System BIOS: Award Software International, Inc. 255.255
Total Memory: 1.87GB DDR2
< Chipset 1 >
Model: Giga-Byte ??? (7910)
Front Side Bus Speed: 1x 200MHz (200MHz)
< Chipset 2 >
Model: AMD Athlon 64 / Opteron HyperTransport
Technology Configuration
Front Side Bus Speed: 2x 1GHz (2GHz)
Total Memory: 2GB DDR2
Memory Bus Speed: 2x 326MHz (652MHz)
< Video System >
Monitor/Panel: Philips 107T (107T2)
Adapter: ATI Radeon X1250
< Physical Storage Devices >
Maxtor 33073H3 31GB (ATA100, 2:28.62GB (C:)
Maxtor 6 Y160P0 164GB (SCSI133:152.67GB (D:)
PIONEER DVD-RW DVR-115D (ATAP:526.74MB (Z:)
< Logical Storage Devices >
Hard Disk (C:): 28.61GB (23.48GB, 82% Free Space) (NTFS) @
Maxtor 33073H3 31GB (ATA100, 2MB Cache)
DSK2_VOL1 (D:): 152.66GB (89.13GB, 58% Free Space) (NTFS) @
Maxtor 6 Y160P0 164GB (SCSI133, 8MB Cache)
NEW (Z:): 14.71MB (CDFS) @ PIONEER DVD-RW DVR-115D
(ATAPI33, 40x CD-R, 40x CD-W, 5x DVD-R, 5x
DVD-W, 64kB Cache)
3.5" 1.44MB (A:): N/A @ Maxtor 33073H3 31GB (ATA100, 2MB Cache)
< Peripherals >
Serial/Parallel Port(s): 1 COM / 1 LPT
USB Controller/Hub: Standard OpenHCD USB Host Controller
USB Controller/Hub: USB Root Hub
FireWire/1394 Controller/Hub: Texas Instruments OHCI Compliant IEEE 1394
Host Controller
Keyboard: Standard 101/102-Key or Microsoft Natural PS/
2 Keyboard
Mouse: HID-compliant mouse
Human Interface: USB Human Interface Device
< MultiMedia Device(s) >
Device: M-Audio Delta 1010
< Power Management >
Mains (AC) Line Status: On-Line
< Operating System(s) >
Windows System: Microsoft Windows XP (2002) Professional
5.01.2600 (Service Pack 2)
Platform Compliance: Win32 x86
< Network Services >
Adapter: Realtek RTL8169/8110 Family Gigabit Ethernet
NIC
< Performance Tips >
Warning 100: Large memory sizes should be made of
Registered/Buffered memory.
Tip 2546: Large memory modules should be ECC/Parity.
Tip 2: Double-click tip or press Enter while a tip
is selected for more information about the
tip.
Old 04-29-2008, 01:18 PM
Squirtypete Squirtypete is offline
Hi M00f
I have pretty much the same setup as you, except I have a Firewire 410 and have experienced the exact same problem.
Go to AMD/ATI site and upgrade your graphics driver to version 8.4
http://game.amd.com/us-en/drivers_ca.../integrated-xp
After complete of format and reinstalls of Windows, calls to M-Audio techs and every other possible driver upgrade/downgrade etc this worked.
Hope that helps
SP
Old 04-30-2008, 11:29 PM
bobbebrown bobbebrown is offline
Hi, I just went to the m-audio support page and don't even see these drivers (Delta_V32_5.10.00.5065.exe), this is what i found instead,, i hope this helps,,,
http://www.m-audio.com/index.php?do=....drivers&f=785
Pro Tools 8.0.4 clicks and pops when recording audio. AliGlenUig 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-23-2011 10:56 AM
White Noise bursts (and clicks and pops) with Pro Tools M-Powered Essential 8 Mr.BC Pro Tools SE and Essential (Win) 5 09-22-2010 03:58 PM
Pro Tools 8 M-Powered Pops/Clicks with Guitar Rig 3 Kontrol Audio Recording slenderfungus Pro Tools M-Powered (Win) 8 01-15-2009 10:24 PM
Pro Tools 8 M-Powered Pops/Clicks with Guitar Rig 3 Kontrol Audio Recording slenderfungus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 12-26-2008 01:13 AM
Clicks/ticks/pops from M-powered 7.1.1 on external HDD Gertgeluid Pro Tools M-Powered (Mac) 0 07-15-2008 05:15 PM
