One file still gets the 9035 error. HELP!!
After encountering several of these 9035 error messages, I went through and changed the file names and various other System Preferences recommendations (File Vault, etc..). All but one of my sessions opens fine. Is there maybe something corrupted on this file I can fix?? I can't play the session at all, nor can I bounce any portion of the audio. I have two different versions of this session (with different names in 2 different places). Could it be that they are confused by linking to the same audio files? HELP!
I'm running 6.4 LE w/ 002R on a G-5 (Panther) |
Re: One file still gets the 9035 error. HELP!!
If you have already confirmed that the session path or any of the associated files do not exceed the 31 character limit or contain any legal characters I would try the following. If you're using dedicated drive for your sessions go to the file menu and select Save Session Copy In, select items to copy all audio files and save the session to your system drive. Unmount your audio drive and see if the session will launch and play. Sometimes when you copy the session to disk allocation is still pointing to the old location. This will insure that this does not happen. Thanks, Digidesign Tech Support |
Thanks! I'll give it a try.
Dae Error 9035 | jbtrustgod | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-28-2010 11:33 AM |
DAE 9035 Error | dillingerfreak | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-29-2010 08:45 PM |
Way around -9035 error?? | MarkPresti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 04-27-2005 12:37 PM |
error -9035? | bhatch | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 02-15-2005 02:07 PM |
-9035 error again | dwilson | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 5 | 01-09-2004 12:36 AM |
