Old 11-06-2020, 12:24 AM
Gregor B. Gregor B. is offline
Default video sync offset - no quarter frame precision
Dear All,
I am currently running into a strange issue with Pro Tools 2020.5 and video via blackmagic: Whenever I set the video sync offset in Pro Tools, I will only see changes for every 4 quarterframes. In other words, I step from 11 to 10 qf - no change, from 10 to 9 qf - no change, 9 to 8 qf - video will delay by a full frame.
This is confirmed with external devices such as Syncheck 3 as well as CathinSync. Will now continue troubleshooting in terms of drivers as wall as PT versions.
Meanwhile: Has anyone ever seen this behavior?
All the best,
Gregor
Old 11-06-2020, 02:25 AM
Farhoof's Avatar
Farhoof Farhoof is offline
Default Re: video sync offset - no quarter frame precision
Yes, it's been like this since forever.
Could be different with an HD IO and video ref input.
Also, without video ref, every time you press play the sync might be a little different, but within a frame though. Based on personal experience, this changes depending on the Decklink driver version which has a dark history of being terrible.
Old 11-06-2020, 04:39 AM
devinemke's Avatar
devinemke devinemke is offline
it has been explained to me by various Avid humans that if your Pro Tools system is locked to video reference (via the SYNC I/O for example) that your Video Sync Offset will always be rounded up/down to the nearest frame edge, thus no quarter frame granularity. the only way to have quarter frame accuracy is to not lock your system to video reference (using internal, or some other clock reference).
hope this helps
Devin Emke
Audio Post Production
Saturday Night Live, NBC
Old 11-06-2020, 05:11 AM
Farhoof's Avatar
I don't have it locked to video ref on my edit rig. It is still rounded to whole frames. It's been like this since at least PT 8 HD and even on the old canopus firewire output (pre-decklink).
Old 11-07-2020, 11:55 AM
Dear All,
All the best,
Gregor
Hi Gregor,
same here. that's normal if your rig is fully gen-locked. You can't offset the video in between frame values when the clocking is forcing it to a full frame grid. I think it's even mentioned in the offset window (?). It will round to the nearest full frame no matter what you enter.
The remaining sub-frame error I compensate with the lip-sync delay in my speaker processor.
F.
HTML code is On
12.6. HD - Video Sync Offset innenhofstudios Pro Tools 12 4 10-05-2016 06:58 AM
Video Sync Offset jumps between +2 and -26 quarter frames danijel Post - Surround - Video 11 02-26-2015 03:40 AM
Video sync offset samplaire Post - Surround - Video 9 11-16-2010 05:50 AM
Keeping Laybacks in Sync (delay compensation and Video sync offset) edit machine Pro Tools TDM Systems (Mac) 6 11-15-2010 11:33 AM
Video frame/field offset when using multiple clips in PT soundboy35 Post - Surround - Video 1 11-16-2008 05:33 AM
