Old 03-02-2018, 04:04 AM
Ale Ale is offline
Default AJA Kona LHI does not work with Protools
Hi
Today I installed a used Aja Kona LHI Z OEM in my MacPro Mid 2010 to replace BMD Intesity Pro
After installing software driver 14.0.1 the system shows the test pattern.
So basically there should verything ok I thougt.
When I load ProTools 2018.1 it seems to find aja because the test pattern goes away and the screen gets black.
But protools does not play video out and it is very slow to scroll.
I can open the aja control panel from within protools so this is proof that the card is seen.
It doesnt matter what I change in the control panel or what i change in protools video output track. The video does does not play out to hdmi
Playing DNXHD36 CODEC (what worked with BMD)
I reinstalled the firmware from the controlpanel but this had no effect.
aja device test was good but system report says WARNING: PCI Flash needs reprogramming
Hardware ID : KONA LHi (0x10266400) S/N O0N91422 XLR Breakout Cable
VideoProc Bit file : 2012/05/21 15:25:30 LHi Main
Driver Version : 14.0.1, Interface 9
NTV2 SDK Version : 14.0.1
PCI Flash : 2012/05/21 15:25:30 WARNING: PCI Flash needs reprogramming
Now I also found that ajaTV or aja control roomdoes not play any videos
So I have no idea what could be wrong.
Any ideas?
Thanks
Ale
Using OSX Sierra 10.12.6 and ProTools 2018.1 with dnxhd36 video
2 PT HD Ultimate 2023.12 6/12-Core Westmere/ 48/96 GB / OS 10.14.6 / 96 I/O / 192 I/O / Omni / BM Intensity Pro (Driver 11.4.1)
1x PT 2023.12 Rosetta / MacMini M1 / 16 GB / monterey / SSL2+
Old 03-02-2018, 06:58 AM
reichman's Avatar
reichman reichman is offline
Default Re: AJA Kona LHI does not work with Protools
I have zero problems with DNxHD video and the AJA T-Tap, but I do run into videos with frame sizes that won't play out the T-Tap. Before giving up, try 720p vs 1080p, ProRes 720p and 1080p, etc.
Nathaniel Reichman
Producer/Re-recording Mixer - New York
Nathaniel Reichman | IMDB | LinkedIn
Old 03-02-2018, 07:07 AM
dr sound's Avatar
dr sound dr sound is offline
My first reaction is that the card you are trying to use is a PC OEM version.
That's why it's asking to be "reprogramed".
I suggest you contact Aja's fantastic support.
Here is a link:
https://www.aja.com/support/contact
They should get you up and running.
Marti D. Humphrey CAS
aka dr.sound
www.thedubstage.com
IMDB http://www.imdb.com/name/nm0401937/
Like everything in life, there are no guarantees just opportunities.
Old 03-02-2018, 11:48 AM
Ale Ale is offline
Yes „dr“
I am already in contact with support. They replyed quickly
I should do some testings. But i can do further test on monday.
Ale
Old 03-02-2018, 01:46 PM
seanmccoy seanmccoy is offline
What's the frame rate of the video you're testing? I just installed an LHi in my PC, and it works perfectly. BUT, I learned from AJA support (yes, they are great) that HDMI can only handle 29.97. So I've picked up an SDI-to-HDMI converter to handle 23.98 and 24 fps video and will switch to the SDI output. Haven't had a chance to test it yet.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7
Old 03-02-2018, 03:01 PM
Ale Ale is offline
My heart beats with 25 frames here.
Yes support is very helpful.
Back in studio on monday and will see......
Ale
Old 03-02-2018, 03:51 PM
Ale
Ah, I didn't note your location before. So since we know Europe is certainly using HDMI, there must be more to the story. Hopefully AJA will sort it out for you. I'll report back after I get a chance to test the converted SDI output on various frame rates and formats.
Old 03-02-2018, 11:11 PM
mgoorevich's Avatar
mgoorevich mgoorevich is offline
I love my Aja LHi working like a horse almost 24/7 for 5 years with a fan removed from the board. I never had any issues with any frame rates including 23.98 and 24 fps is my most common frame rate. Using only HDMI port.
Ale
One thought: have you tried to place the card in other PCIe slot? I remember at the very beginning my card was going off line for 2 seconds and then coming back. Changing slo brought the resolution.
Michael Goorevich
Sound Designer
/ mixer
www.goorevich.com
PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3
MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM
MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24
Old 03-02-2018, 11:28 PM
When I tried to play a 23.98 project from PTHD, HDMI to HDMI, I got nothing, which confirmed what AJA told me would happen. I think the monitor displayed "out of range" or something like that. 29.97 works fine. All DNxHD files. Very curious. I'll have to experiment a little more before moving to the SDI option.
Old 03-03-2018, 01:40 AM
Ale Ale is offline
Hey all
Many thanks for your thougts. Very helpfull.
Back in studio i will try different framerates, changing slot configuration, and what aja told me to check. I should check if the test pattern will go to the hdmi monitor when switching control panel to something other than 25 Frames.
I just wonder why protools reacts very slow when additionally activating the video hardware. the internal video on computer display does not run anymore. No internal ideo on scrolling. Video does not update when jumping to a new frame.
Switching off video hardwar everything i fine
Ale
HTML code is On
video out: aja kona or BM decklink nucelar Post - Surround - Video 8 12-25-2017 02:36 PM
Aja Kona LHe? kkfaudio Post - Surround - Video 1 04-09-2016 07:12 PM
AJA Kona IO XT supported with PT 10.3.6 ?? vudoo Pro Tools 10 1 07-23-2013 09:46 PM
anyone tried PT 8 HD and Kona LS vudoo Post - Surround - Video 0 02-10-2009 11:25 AM
PT HD, FCP, and AJA/Kona Chris Erlon Post - Surround - Video 2 05-17-2005 10:02 AM
