  #21
Old 08-19-2020, 05:40 AM
martthie_08 martthie_08 is offline
Default Re: Still no solution for Analog Summing delay compensation
Is your automation on the return or the outgoing? If on the return things being out of sync with the outgoing isn't an issue. This is where you're not clear.
Franklyn has stated clearly it's a problem with automation on the return (after the analog summing) on the master bus processing.
looking forward to him describing his workflow!
  #22
Old 08-19-2020, 09:24 AM
Actually he hasn't been all that clear. He shouldn't have a problem then with the return being out of sync with the session audio if the plugins he's automating are on said return. They're working on the return audio and NOT the outgoing audio.
  #23
Old 08-19-2020, 10:03 AM
Well, let's take a practical example:
You fold out your mix to an analog summing mixer and return it on a stereo aux, let's call it "master aux" with a compressor and stereo spreader as plugin inserts.
Now you want to automate your "master aux" to have the output level of the compressor and the stereo width of the stereo spreader come up in the chorus.
As is, you certainly cannot do this by selecting the chorus on the edit window timeline in grid mode and pulling up the automation data on the "master aux".
It will be out of sync, because ProTools will not compensate for the DA - AD converter pass on the "master aux".
  #24
Old 08-19-2020, 10:46 AM
Don't use grid mode. Done.
  #25
Old 08-21-2020, 08:40 AM
Franklyn Franklyn is offline
here we go ....
http://duc.avid.com/showthread.php?p...52#post2575552
Analog Latency and Delay Compensation wedge Pro Tools HDX & HD Native Systems (Mac) 9 12-23-2011 12:15 PM
Finally a Solution for Plug-in Delay Compensation!!!!!! Sonic Nomad 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 06-10-2008 09:00 AM
Analog insert Delay Compensation midnightsun Pro Tools TDM Systems (Mac) 7 02-16-2008 10:32 AM
Delay Compensation Solution in M-Powered? fabriciom Pro Tools M-Powered (Win) 4 01-08-2007 06:27 PM
What's the summing solution for mixing ITB? Jon_Atkinson Pro Tools TDM Systems (Mac) 16 05-25-2005 11:01 AM
