Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools M-Powered (Mac)
Old 01-11-2010, 12:21 PM
wreckthisplace wreckthisplace is offline
Default Energy saver settings on Macbook Pro
Hey all
So under 'energy savings' on my Macbook Pro there's an option that says Graphics: Better battery life or Higher performance.
Is this the same as changing the processor performance to 'highest' on the Powermac G5?
I'm only confused because it says nothing about processor performance on my macbook pro but only 'Graphics'.
Should I set this option to 'Higher Performance' when running Pro Tools?
Thanks
Old 01-11-2010, 07:11 PM
dvrooman dvrooman is offline
Default Re: Energy saver settings on Macbook Pro
I’m not 100% on this, but I don’t believe it is going to affect Pro Tools at all. I’m guessing you have a Macbook Pro that has a dedicated video card. The option you are referring to is choosing between the onboard video and the dedicated card. Either options is much more processing power than Pro Tools needs. That said, the onboard video steals from your system memory, so you’d have slightly more ram if you chose the dedicated card (Higher performance).
Old 01-12-2010, 08:57 AM
JrummerJ JrummerJ is offline
Originally Posted by wreckthisplace View Post
Hey all
Thanks
It won't affect pro tools much at all. I am not sure if you are aware, but your macbook pro has 2 graphics cards, the onboard Nvidea 9400 and a dedicated graphics card. When you switch to the higher performance setting, it forces you to log out and then logs you back in utilizing the dedicated graphics card......and using more battery. Keep it on the better battery life unless you are editing video or gaming.
J
Airport & Energy Saver at Off Majorek Tips & Tricks 5 01-19-2010 07:36 PM
Energy saver question bassbuddy 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-30-2004 06:56 PM
10.3.5 Energy Saver on 'Never' but still 'sleeps' command_shift Pro Tools TDM Systems (Mac) 5 11-01-2004 08:24 AM
G5, Energy Saver, Processor performance parak Pro Tools TDM Systems (Mac) 4 01-11-2004 11:57 AM
Energy Saver Dilema snoopy Pro Tools TDM Systems (Mac) 3 04-10-2001 09:03 AM
