#21
Re: Pitch II does not work properly!
It also has 4000 samples of latency when used as a DSP plugin on an HDX system - rendering it completely unusable for the real-time "screwed-voice" stuff we used to do on our TDM system. And when I use it via AudioSuite it shifts the timing around in seemingly random spots. I hate this "update". It's garbage.
#22
Re: Pitch Shift II does not work properly!
JC, why should anyone take the time to do that since the results are ignored by Avid? How many top 25 IdeaScale desires were included in the new PT12? It's either 1 or zero, depending on what really comes out with 12.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
#23
I agree, worthless exercise
#24
Mine has always behaved like that as well but I always use other pitch shift options anyway. The more you shift it, the more artifact-ing you get.
#25
I had the same problem with protools 11 and the latest Antares autotune. Sounded like crap so gave their license back. Very unfortunate.
#26
Pro Tools 12 here. Same problem + sometimes it cuts a beginning of a waveform
#27
I guess this is still a problem, because here I am, wondering why this plugin distorts like crazy when I automate it. Anyone find any fixes, or better alternatives? I can't even rerecord the effect to a new track before it distorts. I don't believe it's an issue of processing power.
#28
I still believe this is the truth
I can't get my Mic to work properly | Djgman925 | macOS | 8 | 08-22-2013 01:53 PM |
does protools ever work properly? | pinnacle | macOS | 9 | 10-24-2011 04:37 PM |
AudioSuite does not work properly. | ali3 | Pro Tools M-Powered (Mac) | 2 | 04-15-2009 05:13 PM |
882 will not work properly with 888 | dwall | Pro Tools TDM Systems (Win) | 0 | 08-30-2007 12:20 PM |
Command 8 not work properly | webby | ProControl, Control|24, Command|8 | 3 | 07-21-2005 09:41 AM |
