  #21
Old 09-22-2019, 08:08 PM
Led Led is offline
Default Re: dbx160 emulation sources?
See if you can find a plugin emulation of an ADR F760 comp, that was used on the Bonham stuff a bit. I know someone made one a little while back.
  #22
Old 09-23-2019, 03:51 AM
Did a little research and that sure was an interesting piece with the gain element (single FET) being driven by 3 side chains. Somebody here in the US is or has done a reissue of the h/w. No idea of that price but it must be expensive and then some.
  #23
Old 09-23-2019, 05:46 PM
Pingafuego Pingafuego is offline
Boz 10db compressor. It’s on sale right now for 29.00
Emulation of Compex compressor used on “When the levee breaks”
https://www.bozdigitallabs.com/produ...db-compressor/
  #24
Old 09-24-2019, 04:12 AM
Thanks for the tip. Interesting is for $10 more one can get the combo of the compressor, eq and channel strip. I don't know the sound of Boz but what about the eq? And what's the channel strip? There's a hyperlink for the strip but it comes back with the same page showing the combo of the aforementioned 3 plugins.
  #25
Old 11-02-2019, 05:29 AM
Originally Posted by amagras View Post
I have the Waves one and for what I've seen it doesn't make as big a difference as it's said it does on drums, it sounds like the hardware I had but I prefer to use it on heavily effected tracks like autotuned rap choirs and far away guitars. I think it's good and if I ever need a different flavour I just use another VCA, especially the BSS and the API, I tend to see the SSL as a more groovy sound but the API can do that when switched to feed back. Good hunting
I have that... and Arturia's 165. As always it depends on your source.
If I recall correctly Andrew Scheps uses one on drums, most likely in parallel, because he is pretty much anti inline compression.
HTML code is On
Wtb: Dbx160 TrentWilliams Buy & Sell 1 10-06-2015 05:59 PM
WTT: 'X' for Waves DBX160 & iZotope Loudness Control TrentWilliams Buy & Sell 2 10-01-2015 09:39 PM
WTB: Waves DBX160 Compressor TrentWilliams Buy & Sell 1 09-16-2015 01:17 AM
External Sources In nutshell ICON & C|24 2 02-28-2002 08:59 AM
does anyone else find dbx160's noisy ? ollie Tips & Tricks 5 06-20-2000 10:32 AM
