Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2019
  #31
Old 07-21-2019, 01:05 AM
WorldStudios WorldStudios is offline
Default Re: NVMe upgrade for Mac Pro 4.1/5.1 Mojave
I ordered the Crest card from amazon USA direct instead of going through the UK branch and that worked. It was pretty pricey with shipping and custom charges elevating the price to just under 300 dollars, but I can take it. :)
Johan Bejerholm
World Studios
Sweden
Phone +46707773443
  #32
Old 07-21-2019, 05:29 AM
K Roche's Avatar
K Roche K Roche is offline
Originally Posted by ghostwriter View Post
I believe that is the case, but Darryl might chime in with a more definitive answer. I could be wrong.
Ok thanks I have decided regardless I will get the dual 1 TB blades and simply partition and use 1 for PT sessions and 1 TB for FCPX projects Given my use is personal so 1 TB storage is plenty for each Application
That way everything will be PCIe express as far as data transfer rate.
Hopping this will give me another 3 maybe 5 years of service with my current machine
System :
Avid HD Omni I/O Interface ...Mid 2010 Mac Pro/ processor- 3.33 6-core Intel Xeon "Westmere" w/ Memory- 24 GB........PTHDN 2018.12 on OS 10.13.6 High Sierra on primary boot drive (SSD PCIe 512 GB Samsung SM951) FCPX files storage on Samsung 970 EVO 1TB and PT sessions storage on 2dn Samsung 970 EVO 1 TB --
"Peace cannot be kept by force. It can only be achieved by understanding" Albert Einstein
Enjoy the Journey
.... Kev...
  #33
Old 07-21-2019, 08:01 AM
ghostwriter's Avatar
ghostwriter ghostwriter is offline
I won’t be partitioning mine, so I wasn’t paying close attention to whether it will work. But, I don’t see why you couldn’t do what you are after. I hope I am not steering you wrong. Worst case, you have full speed use out of 2 TBs.
I hope adding the switcher fan and graphics card fan don’t increase the noise too much. I guess I will find out.
A few of of my favorite toys: Retro Instruments 176 (pair), BAE 10DC (pair), Distressor (pair), Manley Vari-Mu, Sta-Level, Zener, SSL FX G384, API 2500, LA2A, 1176, Bricasti, Massive Passive, Anamod ATS-1, Eventide H3500, TC 2290, Yamaha D5000, PCM 70, SPX90, Roland SDE 3000...
  #34
Old 07-21-2019, 08:58 PM
That's not partitioning in the classic sense.... It's a smart move if you want to simultaneously use both M.2 drives you will get up to twice the IO performance.
  #35
Old 07-21-2019, 09:08 PM
Would anyone know if the the 1 TB yields faster read/write speeds than the 500 GB ,,,like in my current 951 (AHCI) SSD where the 500 was faster than the 250 ?
Good question, the reason for that slowdown in performance on smaller drives is usually just the lack of flash nvram fan-out from the controller, the smaller capacity drives just have less data paths from the controller to the nvram to deliver the performance. As nvram chip densities go up that point may move up in capacity, or may not... all depends on what the vendor is doing (they may use more lower capacity chips to avoid this)
And the answer is the only way I'd know is to look at performance tests by folks like Anantech (the best consumer SSD benchmarks by far). e.g. You can see performance differences here https://www.anandtech.com/show/12670...o-ssd-review/2
Performance differences may also be due to DRAM cache effects (different sizes for different drives) and tuning setting on the controller/firmware. Currently for me I think the 1TB and 2TB drives are a great performance/price/density point. YMMV
  #36
Old 07-22-2019, 05:39 AM
K Roche's Avatar
Humm, I am not quite understanding. "not partitioning in the classic sense"
Am I correct that the Mac will see the dual blade one adaptor situation, as a single , 2 TB drive ? Or will it see as 2 - 1 TB drives ?
If the latter then I can just choose to send PT files to one and send FCPX files to the other ?
If it sees it as a single 2 _TB drive and it is not partitioning , then how would I designate which blade to send the data to ? Or are you saying I would not designate and it's spreading the data over both blades and I just have make two different folders ?
System :
Enjoy the Journey
.... Kev...
  #37
Old 07-22-2019, 08:16 AM
It is not partitioning (a drive) it is two separate drives... just use them that way. The way they can appear as a single drive is with software RAID, the card does nothing but give you two very fast physical devices.
  #38
Old 07-22-2019, 08:47 AM
rballister rballister is offline
Still researching this solution as a possibility for my Mac Pro. Is there full compatibility with a Mid 2010 Mac Pro running Mojave? I guess the card with two drives on the card would allow me to run Pro Tools on one drive and keep the instruments/samples files on the other.
  #39
Old 07-22-2019, 09:12 AM
lancemcv lancemcv is offline
Yes but my point was if you want performance in a Mac Pro Cheesegrater classic look for a switched adapter card that does the PCIe 2 to PCIe3 lane aggregation. I don't think that Sonnet card does that. The card I link to above does.
If you are looking at a modern PC or new Mac Pro Cheesegrater with PCIe 3 slots then there are many more adapter choices out there, including this Sonnet card (and if you want 4 x M.2 drives then it's likely a good choice).
Hey Darryl, I see what your saying about the switch ability, a very interesting card option indeed. I currently have a 256 gig m.2 AHCI which I get about 1300 read / write. I only use it for my system and currently still on High Sierra as I have a flashed 980ti. Happy with performance at the moment but that card looks like a great choice. I saw one review saying they had issues if they only had one drive installed in it. I personally like smaller system drives as cloning is super fast for backup and don’t do any recording or editing on my system drive.
OS X 10.12.1 PT 12.6.1 HD
HD Native pcie / Omni
Mac Pro 2009 upgraded to 5,1 12 core 3.33ghz, flashed Geforce 980ti, Samsung Samsung SM951 M.2 PCIe SSD (AHCI model) pcie boot drive OWC PCIE Mercury Assessor system clone drive, usb 3 card
Pro Tools Native and Omni PT12
Midas M32r console.
Director and Engineer for Front and Center on PBS /MTV
Director and Engineer for Speakeasy on PBS
Engineer for MTV Live new artist series
  #40
Old 07-22-2019, 09:41 AM
Yes, and be super-fast, but remember there is likely no performance reason to *need* to do that, these are so fast you can put everything on one drive if it will fit.... if it does not then sure grab the editors performance. My objection to RAIDing drives is it’s better to just keep things simple as possible. KISS. Most mistakes are user error, not drives failing etc.
Mac Pro 2012 -should upgrade to Mojave? Zak7 macOS 5 06-04-2019 07:51 AM
Mojave? hanksinclair Artist Series 3 05-03-2019 03:19 PM
New 8th Gen i7 with NVMe m.2 SSD spock999 Pro Tools 2018 26 02-22-2018 11:47 PM
Bootable Thunderbolt case for NVMe drives (Samsung 950 etc) propower General Discussion 1 10-27-2016 04:11 PM
Intel SSD NVME/PCIe Porn Darryl Ramm General Discussion 0 04-03-2015 02:02 PM
