Old 10-09-2015, 02:35 AM
Azureless Azureless is offline
Default Command 8 - Compatible
So just a quick question i can't seem to find any information about.
Im close to getting my self a Digidesign Command 8. But im not 100% sure it works with Pro Tools 12.
Any help would be appreciated and of course any recommendations too.
Thanks in advance
Old 10-09-2015, 02:39 AM
peterle peterle is online now
Default Re: Command 8 - Compatible
it will work only until PT10.
not in 11 or 12
foley artist , soundeditor
Old 10-09-2015, 02:50 AM
not in 11 or 12
Any other recommendations for what i could get instead - around the same price?
Old 10-09-2015, 03:42 AM
SOUNDDECISION SOUNDDECISION is offline
I plugged a command 8 into a PT12 rig and it worked....
Is it actually not supposed to work ...or just not "officially supported" ?
As far as I can tell its working fine.... or is there some specific functionality that is broken in 12 that isn't immediately obvious...?
Old 10-09-2015, 04:01 AM
groundcontrol's Avatar
groundcontrol groundcontrol is offline
AFAIK it is unsupported but does fully work.
Can you please send yourself over fiber to go spam some other forum?
Darryl Ramm
Old 10-09-2015, 05:24 AM
Carl Kolchak Carl Kolchak is offline
Mine works perfectly* in PT11 (and it seems PT12 is basically PT11).
It's in the "no longer supported, but not prevented from working" (not the "absolutely will not work" category).
Whilst they're no longer sold, they aren't due for End of Service by Avid, until 2017 I think (search some of my old posts on the subject, I put some links up).
* The only thing that doesn't work is bypassing sends, and that didn't work in PT10 either, so I'm not sure when that got screwed up.
There is also a quirk with how mutes (if I remember correctly) work using the "BOOM" drum machine plug-in.
Other than that, it's solid.
Old 10-09-2015, 07:10 AM
Gemylon's Avatar
Gemylon Gemylon is offline
Thanks for the clarification guys !
Old 10-09-2015, 08:02 AM
sw rec sw rec is offline
Mackie Control....
http://mackie.com/products/mcu-pro-and-xt-pro
OR if you just need basic transport control and you have an I-pad, the AVID Pro Tools Control app works quite well, and it's free!
Old 03-31-2016, 02:16 PM
john1192 john1192 is offline
i know this is an older thread but what do you think the chances are the Command 8 is going to work much longer ???
OS 10.12.6 for PT 11.3.2 & 12.4 & above
Mac Pro 6-core 3.33ghz (2012) 24gb ram 256gb SSD
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS10.12.6 - PT 12.4 & above
lynx AES16e-SRC & Aurora 16
Artist Transport & iPad - Pro |Control - EuCon 3.7 (older Euphonix Branded MC Transport)
Old 03-31-2016, 03:02 PM
Neale Neale is offline
Mine died with a power surge, but I'm thinking of returning my Artist Control and paying less than half the dough to get it fixed. At least it worked - FLAWLESSLY. Not sure what the "bypassing sends" issue was, I don't remember ever having an issue with it at all. Ever. I think I was running it until 12.2 or 12.3, but with 12 for sure.
D-Command Firmware update backwards compatible? inky macOS 4 09-18-2014 01:48 PM
Command Keyboard Focus mode ' E ' command bug ? vudoo Pro Tools TDM Systems (Win) 2 09-10-2009 05:49 AM
Leopard / PT 7.4-PR / Command|8 not compatible? eric22rr ProControl, Control|24, Command|8 2 06-10-2008 11:38 AM
Total Loss of Command 8 Command/Modifiers John Pisciotta ProControl, Control|24, Command|8 1 05-13-2005 10:30 AM
Command 8 ANd 001 compatible? eddierojas ICON & C|24 0 04-05-2004 07:47 PM
