Insert Measures
I would like to insert 4 bars at the beginning of a song but I've been unable to find a reference in the guide as to how to do this. Could someone give me some direction on this? Thanks for your help.....MusicGuy
Re: Insert Measures
Easy way is to select all then slide the region 4 bars.I assume you already have recorded audio and just want to put 4 bars at the beginning.Or you can select all and then go to EDIT>Shift and type in the amount you want to shift the audio
Bazzle |
Re: Insert Measures
Thanks Bazzle. That worked great.
MusicGuy |
Re: Insert Measures
Is there some way to make the existing markers shift when you do an insertion like that? or do you have to move each marker individually?
Re: Insert Measures
I personally recommend you change the session start time in the Session Setup Window.. however, to have markers included in the edit.. shift + click in the Marker timeline to include them while editing.
Rail
Re: Insert Measures
Bazzle |
Re: Insert Measures
I change the start time as SMPTE -- the top of my session is never bar 1 anyway -- and your session start time should normally be around 1 hour.
The advantage to changing the session start time is that Original Time Stamps remain intact. BTD doesn't have to start from the top of the session.. simply make a selection before BTD. Rail
Re: Insert Measures
Thanks..I guess my answer to the original poster, Music Guy, was probably the best for his particular situation..Just wanted to make sure
Bazzle |
add measures How is this done ? | mgmazzei | macOS | 3 | 12-29-2012 02:46 PM |
Measures disappearing... | stretto | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-24-2003 12:16 AM |
How to insert time / insert measures, without upsetting tempo map and markers | imp | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 03-25-2003 05:45 PM |
Adding P/U measures in PT | Jazzbass56 | Pro Tools TDM Systems (Mac) | 2 | 03-26-2002 09:08 AM |
Resetting measures | Nashville Bass | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 01-01-2002 05:43 PM |
